SOURCE: Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
SOURCE: Sata hard disk
Hi, i have the P4i45GV and it doesn't support Serial ATA.You'll have to buy a IDE hard disk.
SOURCE: sata 3 port on motherboard sees sata drive as a floppy drive
Choose in bios the setting about HDD. Choose Enhanced Sata compatibility. Now you can plug 4 satas
SOURCE: SATA dvd writer doesnt works with D101GGC
you have another sta device conected in your pc?
go to the bios to see sata configuration chip.
i think there is to resolve your problem
SOURCE: i have asrock prescott 800 ddr400 fsb800
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard;
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0 Next, is a link for the SATA convertor;
http://www.startech.com/item/IDE2SAT25-40-Pin-Female-IDE-to-SATA-Adapter-Converter.aspx
Cheers'
Mike
what type of connector?? Do I need IDE to SATA converter??
