Question about Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL 5 Router
Nortel 1050 & BSR222 VPN Connection
Hi there, I was wondering if you all can help.  I have a Nortel 1050 at the main location with a static IP and 3 BSR222 remote locations with dynamic ips.  I need to create VPN tunnels to the main location but cant seem to get it right.  Can you help?
  • al pate Dec 28, 2007
    i have bsr222 on both side and i can connect with static ip but i can't do with dynamic ip at one end
  • 3 Answers
If you want to have a dynamic IP at the remote site you can forget about it, I placed a support call to Nortel and they told me that even if the NAT traversal option is there in the BSR222 they do not support it!!!
I was able to use a bsr222 with a static ip accepting connection from linksys using dynamic, this works.
see some example doc at www.chbr.info/linksys_bsr222.zip
Posted on Nov 06, 2008
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
Aug 27, 2013 | Computers & Internet
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
Nortel 1050 and BSR222 VPN Connection
1.  What you have is a "software settings" in several  locations that require "exact entries".  Without us seeing what  "entries" are being asked by the programs or what data needs to be inserted by the routers at each location, there is no way anyone could possibly solve your problem long distance.
2.  The basic generic information was supplied to you at another website you visited but obviously did not help you.  I appreciate you having the confidence by asking anyone here to guide you but I think you need to have some one physically there to fix the problem.  If someone here knows the answer and can solve this problem by all means jump in.
3. My solution is for you to look in the yellow pages for your town where you live under "networks" or "computer networks".  Some one locally should be able to come out and solve this for you.  VPN networks at this level require a "hands on" solution unfortunately and not a "cook book" answer.  Get one field wrong, you will spend days troubleshooting it.
This is the best solution for your problem in this case.  Anything else would be a great disservice to you.
Oct 23, 2007 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
CAN'T CONNECT TO WIRELESS PRINTER AFTER VPN TUNNEL CONNECTION
Check the IP segments. Your printer & your machine would be falling in the same IP segment as your job network. Change the IP segment of your pc & printer.
Sep 01, 2009 | Arris SURFboard SBG900 Wireless Router...
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to rabih_2@hotmail.com
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Feb 18, 2009 | Dell PowerEdge 2600 Server
How to connect Nortel BSR222 (Business Secure Router 222) with tplink
rj11 are connectors used to deliver signals to a device. Mostly, modems will be able to support this type of connection. Make use of a modem, bridge it and connect the router to it.
Aug 17, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
Bsr222 tunneling problem
What are you connecting into the bsr at distant end, lap top or ip phone
Dec 28, 2007 | 2wire (1000-400108-001) Router
Nortel 1050 connecting a VPN to a BSR222
Does the 1050 support tunnels to the BSR222 with dynamic addressing?
Oct 24, 2007 | Computers & Internet
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Open Questions:
Nortel 1001s secure router qos configuration i have a nortel 1001s secure router i would like to configure qos on it i managed to managed to configure qos but it seems not to be working as when i try to calculate or monitor my bandwidth i seem not to get any data, here is a view of the running config of the router R-KEN-BITU-001 > sh run Please wait... (up to a minute)module serial 1 cable_type v35 clock_rate 2000000 crc 16 mode dte clock_source line data_mode normal exit serialinterface ethernet 0 description "Bitumen LAN" ip address 10.113.250.254 255.255.255.192 mtu 1500 qos exit qos exit ethernetinterface ethernet 0.1 description "Nortel Phones" ip address 18.113.119.4 255.0.0.0 exit ethernet interface ethernet 1 description "KDN link to HQ" ip address 172.16.18.2 255.255.255.252 mtu 1500 qos add_class NortelRTP root-out cr 40 br 128 add_class NortelDATA root-out cr 88 br 128 class NortelRTP add_src_ip 172.16.18.0 255.255.255.192 exit class class NortelDATA exit class enable policing outbound enable policing inbound exit qos exit ethernetinterface bundle Bitumen exit bundleinterface bundle bitumen exit bundle hostname R-KEN-BITU-001log utctelnet_serverssh_server exit ssh_servertelnet_banner banner1 "TOTAL KENYA LIMITED" banner2 "BITUMEN PLANT" exit telnet_bannersystem display-boot-config noip load_balance per_flow route 0.0.0.0 0.0.0.0 172.16.18.1 1 dhcps pool Total-Bituen exclude-range 10.113.250.244 10.113.250.254 exit pool pool Total-Bitumen domain total_kenya_hdq.com dnsserver 10.113.118.5 tftpserver 10.113.255.39 netbios_name_server 10.113.118.5 lease 604800 network 10.113.250.192 255.255.255.192 default_router 10.113.250.254 commit exit pool interface ethernet0 enable exit dhcps exit ipfirewall global algs exit algs max-connection-limit self 2048 exit firewallfirewall internet exit firewallfirewall corp policy 1024 out permit exit policy exit firewalltftp_servergui enable exit guisnmp-server snmp-enable community bituro ro community biturw rw location Bitumen-Plant chassis-id R-KEN-BITU-001 trap-version 1 exit snmp-server please assist in any way as im being fried on this... please thank you
Oct 29, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
See all Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL 5 Questions
Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL 5 Router Logo
511 people viewed this question
Top Nortel Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
J John
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
