H3-00 fault Fault code as above
  • damiannunn Jun 03, 2009
    Thank you the above did the the trick.
    President:
  • 1,197 Answers
H3 - 00. This means High Temperature in the heater section, proberbly caused by a faulty thermistor.
Firstly try a reset, please press the following buttons IN SEQUENCE:-
Program - Interrupt - Clear - Interrupt - 1 - 4 - Print.
If this cures the fault, your good to go, if not you'll need to replace the part.
thank you
Posted on Jun 02, 2009
Engine management light is on s o done self test on Ford focus 2000 it's come back with R22 and E001 fault code Amy ideas what it is at all
Hi there , good evening to you
Ok the cluster self test is no good these are internal cluster codes and are not reliable or relavent
You need to have a diagnostic fault code check done on the PCM
Nearly all garages have the equipment to do this
The most common faults we see are intake manifold runner control issues and HEGO (lambda sensor faults )
If the vehicle is still running ok eg no misfire then it will probably be one of the above
Again this is fault code dependent as the fault code check is an imperative part of correctly diagnosing this issue
Mar 10, 2016 | Ford Cars & Trucks
I went to have my car scaned, but showed to many trouble codes 10 codes in all! my problem I'm having is the engine has an intermitting miss, either at idle or rolling down the road! smooths out then
Wow....Well a leak at convertor can cause all engine management sensors to read lean mixture, then they all compensate by richening up mixture causing your problems. Start with the simple. Check the ribbed tube leading from air filter box to intake. It may have cracks open on bottom of hose you can't see from above. If it does, replace, get them at local junk yard as well as new.(Cracks or breaks when changing air filter) Check the 2 connections plugged into that same tube, make sure not leaking/have tight fit. Check all plug in connections all over the engine to make sure none are loose. Fix the leak at convertor. After leak fixed, remove battery negative cable for 2 minutes and put back on. This will clear codes fixed pertaining to leaking convertor....Now have your computer check on fault codes again. Auto parts stores do this for free! Write down all fault codes showing faulty. I imagine you will have some or all of your 3 exhaust sensors above the converter showing bad. These you can replace at about $45 each. If so Search each of your fault codes online (FIX 2000 MERCURY SABLE FAULT CODE# ) There are You tube videos on how to replace. One of the exhaust sensors is close to back of transmission, repaid from above laying blanket over engine to reach. Pull off Batt cable again for 2 min, put back on. This resets fault code and engine management system. Give it a ride to auto parts store again for code fault testing. Write it down if still bad. Two more things, EGR valve, EGR pressure sensor next. I will check back later.
Dec 10, 2014 | 2000 Mercury Sable
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
Nov 18, 2014 | 1990 Lexus LS 400
I have a fault code 249 from my Fisher and Paykel 8kg washing machine. What does this mean?
I didn't know the codes went this high! it will be a motor controller fault I would suggest, as all other faults above 140 are motor controller.
Aug 28, 2013 | Fisher and Paykel (IWL12)
Peugeot 206 XS Can't accelerate above 1000 rpm at any gear
The very first thing you need to do here is have the engine control module scanned for fault codes with an OBD2 fault code reader or scan tool. Once you have the fault codes then you can diagnose the cause by the fault code or codes received.
Mar 30, 2017 | 2003 Peugeot 206
Truck will be running fine, then all of a sudden it will completely shut off. After we wait a few minutes and pump the clutch and make sure it is all the way to the floor it will start, sometimes. S
You need the engine computer scanned for fault codes, i thank you have an ignition control problem like a module or distributor pickup coil issue. These parts whenthey fail should leave fault cdes so get them read.
Next, the check engine light will pause shortly followed by the second digit of the trouble code. For example if the check engine light blinks once and pauses followed by six blinks the trouble code number would be 16. If no code is present the check engine light will stay one constantly. To restart code gathering turn the ignition key to the "off" position, wait three minutes and turn the ignition key back "on" again without starting the engine. Remove the jumper wire once code gathering is complete. To clear code after the repairs have been made remove the negative battery cable for one minute and reconnect.
Toyota Diagnostic Connector
Toyota Code Definition Table
Code 11 Momentary interruption in power supply to ECU (electronic control unit or computer) up to 1991
Code 12 Engine revolution signal missing Code 13 Rpm signal to ecu missing above 1000 rpm
Code 14 Igniter signal to ecu missing
Code 16 A/T control signal missing from ecu
Code 21 Main oxygen sensor signal fault
Code 22 Water temperature sensor circuit fault
Code 23 and 24 Intake air temperature signal fault
Code 25 Air/fuel ratio LEAN
Code 26 Air/fuel ratio RICH
Code 27 Sub-oxygen sensor signal or heater circuit fault
Code 28 No. 2 oxygen sensor/heater signal fault
Code 31 and 32 Air flow meter circuit or Vacuum sensor signal fault Code 34 and 36 Turbo-charging pressure signal fault
Code 35 Altitude compensation sensor signal fault
Code 41 Throttle position circuit fault
Code 43 No starter signal to the ecu
Code 51 AC signal on; DL contact off (in transmission shifter with diagnostic connector jumped)
Code 52, 53 and 55 Knock sensor fault Code 71 EGR system malfunction
Code 72 Fuel cut solenoid signal fault
Code 78 Fuel pump control signal fault
Code 81, 83, 84 and 85 TCM communication fault
Jun 28, 2012 | Cars & Trucks
1996 monte carlo fault codes po300, 441, 705,
THESE ARE FROM THE GM CODE DIFINITION MANUAL, U NEED TO TAKE THIS TO THE DELAER, U HAVE SOME SERIOUS PROBLEMS TO GIVE THIS MANY CODES.
P0300 - Engine Random Misfire Detected
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0705 - Trans Range Switch Circuit
P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
P1662 - Cruise Lamp Control Circuit
P1672 - Low Engine Oil Level Lamp Control Circuit
P1870 - Transmission Component Slipping
Mar 24, 2009 | 1996 Chevrolet Monte Carlo
Fault code F3, then F2
Well here's the details about those codes:
F2 :-
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
F3:-
Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
167 people viewed this question
jasbo
jasbo
