Question about Peg Perego John Deere Turf Tractor
Only goes in reverse
Will only drive in reverse. Just got it used from a friend in perfect condition...they were getting rid of it because they didn't want to try to figure it out. Son's birthday is in 2 days and want to have it working by then....HELP
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Do either of the forward gears work?
Posted on Jun 06, 2012
2002 ford explorer will drive forward but wont move in reverse...what could be the cause?
bad transmission. if it shifts through gears going forward but will not do anything in reverse it is most likely a bad transmission. reverse is usually the first gear that goes out .
Dec 07, 2014 | 2002 Ford Explorer
Why won't my 2003 jeep go in reverse
(but all other gears ok?)
shoe drops.
so is park lock unlocking and you can get to N?
PRNDL.>
driver ok,
L ok
what?
or all is good, all gears and shifts perfect and drives perfect but
Reverse is like neutral,? slips
or is wrong gear, goes forward>
what?
Sep 08, 2014 | Jeep Cars & Trucks
Van problems
Get rid of it--- trans is shot
That vehicle has one of the worst transaxles
made,not worth fixing a 16 year old vehicle & it
appears head gaskets are an issue also on them
Feb 01, 2013 | 1997 Ford Windstar
I have a automatic 1996 ford fairmont ghia, i am having problems with the reverse gear, sometimes it works then other times it drops completely out! all the other gears work perfect, i have no dip stick to...
need to get friendly mechanic to check oil condition and level,for starters,could be shift solenoid or reverse gear itself,probably going to be trans repair i would say,has the car got 170,000 plus klms
Oct 26, 2009 | Ford Fairmont Cars & Trucks
Transmission Problem or ????
how many miles probily internal damage
Jul 28, 2009 | Dodge Ram 3500 Cars & Trucks
The display samsung t240hd monitor randomly/intermitently loses sharpness. Goes from a perfect hd picture to a analog type picture. White space on menu bars in pc modes goes from a crisp solid grey...
Hi im josh in cebu phils. may i help? Friend your problem focusses on to hardware. first try to check your video card clean or change then after try to use the monitor.if it still appears the same. 2nd try to use your monitor in other pc.if still appears. the problem is your monitor. if you knew somebody around that could fix tv or appliances let him see your monitor.there maybe one of the capacitor in the monitor that is damage or burn out.let him change it. so that it will work again in condition. good luck.
Feb 17, 2009 | Computers & Internet
No reverse on 95 Dodge intrepid
first check all fuses body grounds because if the trany isnt getting a good ground would cause this problem and if those are all ok the reverse sylinoid failed wich is in the trans.
Feb 01, 2009 | 1995 Dodge Intrepid
When i put my car in reverse it won't move but will drive forward perfect and is full of transmission fluid
Assuming this is an automatic transmission, odds are you have lost a band in your transmission, this will require a rebuild,  you may also notice it will fail to shift into high gear as well?
Oct 29, 2008 | 1984 Oldsmobile Delta 88
Peg Perego John Deere Turf Tractor Logo
99 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
