remove the rear drums then inspect and manually adjust the shoes auto adjuster ,clean the lip off on the outside of the drum so the shoes just about allow the drum on ,this is the correct way not screw the cable setting up to max ,do it my way and the brake pedal will be hard as you have reduced the reserve travel and the handbrake will have two /three clicks ,when you do this make sure the rear brake shoes which have trhe handbrake lever ,make sure this lever is right back if not slacken the handbrake cable to allow the cable to come back in case some weekend mechanic or a dealer fitter has tightened the cable only ,the former as they dont know and the later because their on bonus payment
hello, parking brake adjustment,,if you look under the tractor behind the right wheel next to the trans. you will see a round disk with a small shoe,turn that in to adjust brake,hope this helps,,
Hello, My usual Brands are Ford products, but Foreign cars usually use simple, less expensive ways to do things. Assuming the brake pads are good, there should be a cable connected to the handbrake. You would usually pull the handbrake up to engage about 1/4 the way to engagement and lock it there.
Then you would go underneath the car and find the cable that stretches from the handbrake lever to a juction with a second cable. There should be an adjusting thread somewhere at this intersection.
With the rear wheels off the ground, you would tighten the nut on the threads of the handbrake cable until you hear rubbing in the rear brakes. Then get inside the car and pull back on the handbrake lever and you should not be able to move the rear wheels with the handbrake set. You then release the handbrake 100% and the rear wheels should turn mostly without noise.
Now if you can not find an adjustment nut under the car, it is possible the handbrake adjustment nut is under the handbrake cover/boot inside the car. Still use the same process of setting the lever 1/4 engaged and tightening the threaded cable until the rear wheels start dragging.
remove the back brake drums ,slacken handbrake cable then run a mini grinder around the lip on the edge of the drum .Then adjust the auto adjusters manully so when the drum is push on it just goes on ,tap with a hammer all around the drum to level the shoes and if need be adjust up a bit more ,then when finished re-adjust the cable so you have three notches on handbrake lever
Generally you should not have to replace the parking brake cable. It should have an adjustment to give more slack or takle up slack as needed. Get a Haynes manual (around $20 at autozone) for your car. It will tell you how to adjust the parking brake cable and/or how to replace the cable if that is needed. In most cases it is just an adjustment that is needed
1. Raise the vehicle and release the handbrake. 2. De-adjust the handbrake cable.
Remove the locking pin.
Slacken the adjuster locknut.
Slacken the adjuster until the levers on the callipers have returned to their stops.
3.
Paint alignment lines on the lever and caliper
4. Tighten the adjuster until the caliper levers move from the alignment
lines.
5. Apply the handbrake to equalise the cable.
6. Tighten the adjuster locknut to a minimum of three clicks and a maximum
of six clicks.
7. Fit a new adjuster locking pin.
8. Lower the vehicle.
The handbrake adjuster is under the centre console behind the lever. If its coming too high, check that the levers at the rear brake calipers are free and moving back to their stop position - they are prone to seizing up on older or little used cars. They can usually be freed off with a bit of lube and working the lever back and forwards. If that dosn't work, unfortunately you'll need new calipers. Do not adjust the handbrake cable unless the caliper levers are at their stops as this seriously reduces handbrake efficiency!
