Question about Panasonic PT-47WX49 47" Rear Projection Television
Power problem Our TV is dead. It would turn itself off after about 5 seconds of being turned on, and now it won't even turn on. I've called panasonic who gave me the name/number of a tv reapir shop but we've not taken it in yet. Anyone with a clue what could be wrong and/or how expensive this might be to fix? Thanks for your help in advance!
  • 5 more comments
  • erimirart123 Nov 03, 2007
    my tv.is dead it woul turned on and nowork natin
  • Anonymous Nov 08, 2007
    Our TV is an HD RearProjection Tv. We have had it for four years. You would turn it on and it would come on for a few minutes and then click off or would have problems starting all together... Then one day it would start and no picture and the bulb light on our TV would come on... Do I need to replace a bulb and if so where do I find it and how much is it?
  • country man Nov 13, 2007
    My Panasonic will not turn on, un plug it. It will cone on then go off. I see others have the same problem.Can I fix it or will i have to send for a repair person. thanks, Ron Countryman@att.net.
  • Anonymous Nov 22, 2007
    dead set no power
  • Tizbroke Feb 11, 2008
    I have a Panasonic 47" rear projection HD TV from 2004. It went dead this afternoon and wont even power on. The power light flashes a few times and then goes away.
    Did anyone get this fixed ? How much does it cost?
  • chubby6 Mar 19, 2008
    tv screen went yellow then shut off wont turn on when power button is pushed light flashes several times
  • parmebaby Mar 22, 2008
    I have the PT47WX49E (2001) and it is also completely dead. I can unplug it and replug it in and than I power up and it will stays on for about 4 seconds, solid red light for the power button, no blinking. The Screen barely gets to show the display when the set goes dead. Can somebody forward the service manual. Any suggestions on were to start?
    Thanks for any help,
    Joe
    parmebaby@sbcglobal.net
I have the exact same symptom model# PT-53WX42F. Bought new in 2002. Turns on for about 5 seconds perfect picture, then turns off. Power light blinks 3 times then repeats. Any guesstimates for repairs?
e-mail me at "nikao2-at-sbcglobal.net" thank you...!!
Posted on Feb 07, 2008
My Panasonic LED TV picture goes away after a few minutes
Could be a bad connection that disconnects when heat in the system causes it to expand. Take to a pro or call manufacturer, they might have a recall or free repair available.
Apr 03, 2015 | Panasonic TC55LE54 55" 1080p 120Hz SMART...
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Is totally dead. First, I received blinking led, but right now, nothing. Si habla espanol, mucho mejor para mi, si no, puedo conitnuar en ingles.
Hi Eduardo,
First of all, thank you for contacting Fixya.com regarding on your TV problem.
I'm assuming here that your TV's model no. is TCP50S2. Most of the blinking LED on Panasonic TV's has a corresponding error code let say the led blinks 5 times(won't turn on), it is a 5 Volts malfunction either on the P board (power supply board) or on A board. Some of the blinking led error code are related to faulty electrolytic capacitor on the power supply board. It will dropped the normal working voltage of the power supply and will disable the unit. Faulty capacitor most of the time has a physical indication of fault like bulged/dome at the top and can be easily identify through visual inspection. Watch the video below for more info.
In your case, you've mentioned that the TV is totally dead set now, this is an indication of fault either on the P board or on A board but most cases I've encountered a faulty P board (power supply). I've suspected that your P board gone to multiple parts malfunction aside from the capacitor.
If you are going to DIY, I would advice you to check the output of the P board using a multimeter to confirm its condition. Once it has a missing voltage, replaced the entire board. Click it HERE for the P board's replacement.
Hope I helped you.
Have a nice day!
Ratings and feedback are highly appreciated!
Kind Regards,
Jdvillanueva
Dec 03, 2011 | Panasonic TCP50S2 50 in. TV
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Beeps when turned on then power light blinks 5 times
sound like the b+ line is not getting the voltage call a tv repair tech.
Feb 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
