Question about Vizio GV42L 42 in. LCD Television
Vizio sv420xvt pip
I have a 42 inch but i cannot get the pip to work, when i press i say not available please check parentl setings, can anybody help me with this I have found no parental settings either. I had an old 42" vizio where the pip was no problem, now the new (1080) vizios (i have had 2 now)i get the same message and there is no parental settings.
  • Devon Sacco
    Devon Sacco May 11, 2010
    This is how you should get to it,
    When the MENU button is pressed, the On Screen Display (OSD)
    appears on the PICTURE adjustment page.
    Press the button to display the SETUP
    page.
    Press the ▼ button to highlight Parental,
    and then press the button.
    When you are trying to use the PIP, what are the 2 sources you are trying to put on the screen?
You have to be in 'TV' mode to access the parental settings option. Not sure why. When it asks for the code it's 0000
Posted on Oct 19, 2009
  • 92 Answers
Go through your owner's manual and check for the compatibility list. It will give you a scale of what could be use with what. If you don't have owner's manual, you can download it at vizio.com under support and download.
Posted on Jun 16, 2009
2 Suggested Answers
SOURCE: vizio sv420xvt pip
You have to go into the "Parental" settings and change the "Rating Enable" setting to off. Default password is 0000. The PIP will not work if your second source is fed into one of the AV inputs. It must be a composite or digital input. You should see the PIP menus once you change the Parental setting even if there is no other source turned on. This info is not in the book - had to call tech support.
Posted on Jan 17, 2009
Vizio 42 inch smart tv Model # M420sv
You have to check the audio settings of your tv. There would be n option which allow you to choose the option between internal speakers or external speaker. You have to choose it as external speakers of amplifier.
If you wish to get some more details then check the following link
http://electro-medical.blogspot.com/
Jul 22, 2016 | Vizio M420sv 42 Inch Class Edge Lit Razor...
My vizio won't turn on and has code 5.1
http://cdn.vizio.com/documents/downloads/hdtv/SV420XVT/SV420XVT_Users_Manual.pdf ..not sure if this will help you out its the only manual i can find.half way down the page it gives yoy faults and what to check for.
if this is not the manual please let me know.
Jul 12, 2010 | Vizio L32 32 in. LCD HDTV
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Connection error from ps3 to tv.
When you hit the power button from the console, hod it until it beeps at you twice and it will reset the video settings. I read this on a post from gamespot. I hope it works.
Jul 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Vizio SV420XVT. There is a green line from top to bottom on the right side of screen. Help me fix this, just went out of warranty
A single line out means a bad LCD panel..The cost for parts will exceed the cost of replacing the TV...
Jul 23, 2009 | Vizio SV420XV 42 in. LCD TV
SV420XVT cant get extended television giude to display
The guide information that is in the manual is not correct. If you are using the manual that came with your television than look around for an addendum that states how your guide will work. Just a piece of paper that was included with your television. They included this addendum with televisions that had the guide info already printed in the manuals. The full guide is not available on newer VIZIO televisions. Also, if you have the guide now and need your television needs service, you may not have the guide feature after the service. This is something that is not related to VIZIO televisions alone. Many other name brands will not have the full guide. It is a licensing issue and until resolved you will not have the guide.
Apr 05, 2009 | Vizio GV42L 42 in. LCD Television
Tiny picture
try hitting the PIP button on the remote, sounds like it is in PIP mode, and the vizios have many configurations of PIP
Mar 19, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
Cannot get pip function to work. i try to select pip and it says not available, but in my manual it says it is available. its really weird. it is even listed on my remote, but does not work when i push it....
Some models of the TV have PIP as an option, but not installed, and to make it cheaper, they use the same remote and menus, just disable the option, as it's not supported. Best to check the Manufacturer's website to make sure that it does do PIP, not that a related model which has the same user manual does PIP.
Mar 15, 2009 | Vizio VO47L 47 in. LCD TV
Vizio sv420xvt pip
Jan 11, 2009 | Vizio GV42L 42 in. LCD Television
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio GV42L 42 in. LCD Television Logo
506 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
