Question about Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004 messenger encountered a connection problem.Please check the network connection and then click "Try Again".(81003004) i have similar problm .in above solution ,i checked my setting but its not yet solved.
    President:
  • 1,197 Answers
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Posted on Jun 02, 2009
When i login to yahoo messenger a messege displayed 81003004
This error code is displayed if the registry entry has some invalid entry
Go to start > Run > "regedit"
try deleting the reg key:
"HKEY_CURRENT_USER\Software\Yahoo\pager" and exit messenger and login.
Jan 15, 2010 | Yahoo Computers & Internet
I get error as 81003004 while login
Here is a site that show's you how to set up an HTTP Proxy server in Yahoo Messenger which should fix the problem:
http://www.theanand.com/blog/index.php/techie/81003004-yahoo-messenger-login-error/
and here is the site where you can find a LOT of good proxy servers to use:
http://www.proxy-list.net/fresh-proxy-lists.shtml
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Thanks!
Jul 17, 2009 | Yahoo Messenger
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 10, 2009 | Yahoo Messenger
When ever i try to login to messenger occurrring an error81003004
okay
go to
C:\Program Files\Yahoo!\Messenger\Profiles
then delete all profiles from there .
Then restart your computer then check .
If still problerm remains first uninstall yahoo messanger from add remove program in control panel.
Then downlaod from here and install.
http://www.soft32.com/download_30.html
Jun 15, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Jun 02, 2009 | Yahoo Messenger
Messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/messenger/mstanoconnect.html
Feb 26, 2009 | Yahoo Messenger
Error message 81003004
try this solution
Dec 22, 2008 | Dell Inspiron E1505 Notebook
Yahoo Messenger Logo
397 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
