Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower wont stay running
Craftsman 19.5 hp rider wont stay running, spray carb cleaner in carb keeps it going Where can we get a replacement vacuum hose? Has a lip that inserts into top of vacuum. I am in Alaska and sears wants $38 to ship a $3 part!
  • 20 Answers
Take hose off and take to local hardware store.probly got something that would work
..freaken sears..')
Posted on Jun 02, 2009
My 1984 Rabbit Convertible runs great, but has a surge in idling and after driving for a short while when going to stop, stalls out?
you are right it is a air leak but either at the intake gasket or tb gasket seeing you replaced the hoses already. spray some carb cleaner around those areas while running and see if idle changes this will pin point the area of trouble. make sure you dont have any spark plug wires arcing out cause this could ignite the carb cleaner.
Dec 15, 2014 | 1984 Volkswagen Rabbit
My 5 hp craftsman tiller won't stay running changed gas sprayed carb new plug started it ran ok next day starts won't stay running dies fast like no fuel but can smell gas.
when it dies see if it will restart using a shot of starting spray in the air cleaner if it starts or sputters, sounds as if you have a plugged up carb you will need to dissasemble and soak in white vinegar for a few hours to un clogg (carefull with any gaskets)
if still nothing even with spray then you have a weak/defective coil or dammaged spark plug (start with plug replacement)
Aug 06, 2014 | Garden
Running issues
BASICS, BASICS, BASIC......
**CHECK PLUGS, WIRES, FUEL FILTERS, RUN CAR AT HIGHER RPM AND SPRAY CARB CLEANER DIRECTLY INTO CARB, CHECK (WITH SPRAY CAN OF CARB CLEANER) FOR VACUUM LEAKS BY SPRAYING ALL AROUND INTAKE AREA, VACUUM LINES ETC...
IF IDLE SMOOTHS OUT OR RAISES..CHANCES ARE THERES A VACUUM LEAK
Jul 21, 2013 | 1995 Geo Metro
My craftsman 18.5 HP OHV will not start
first see if the fuel pump is working remove the hose from the carb and crank it over if fuel sprays out it works the see if you have power to the solenoid to the bottom of the carb if so remove the solenoid and put power to the wire and a ground if it is stuck carb cleaner can free it up if it moves remove the bowl from the carb and see if fuel is getting inside the carb a bad needle vale would stop it from getting threw
Aug 18, 2012 | Craftsman 18.5 HP 42"
99 dodge 1500 p-up-318 block starts fne, warms up and starts to hear air suction sound from under the hood, motor kills and then wont stay started after that...
check all the vacuum lines, and the PCV valve, get a can of carb cleaner, and while the motor is running, spray short bursts of the carb cleaner all around where vacuum lines are located, if the motor rev's up thats where your leak is going to be
Aug 12, 2011 | 1983 Dodge Pickup
I have a craftsman 6.75 hp push mower. It starts
Use fresh gas only first
then if still an issue remove carb.and clean all components and orifices with a good carb. cleaner and air hose or soak it in a automotive grade carb cleaner,spray residue with carb,cleaner and blow dry with air--reassemble and reinstall
May 28, 2010 | Garden
Truck won't stay running.
Sounds like you have a vacuum leak check all rubber hoses going to the intake manifold .
Jun 07, 2009 | 1992 Chevrolet S-10
Won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
May 07, 2009 | Garden
Mower will not stay running unless primer button continuouly pushed. Gas seems to not be independently flowing, requires manual priming to stay running. As soon as primer gas used, will stop running.
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Apr 12, 2009 | Garden
Engin dies after warm up then, hard to restart, will not stay run
use carb cleaner to trace remaining vacuum leaks .spray while running around plenum and hoses..engine will get happy when it sucks in carb cleaner.. that will allow to find leaking area ...good luck
Dec 17, 2008 | 1990 Toyota Pickup
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
417 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
