Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture on sony trnitrion is shifted to the left and picture is cut off.
We have the same problem and I'm sure it's not the cable box or DVD player that has the problem.
5 Suggested Answers
SOURCE: My sony Tv picture has shifted to the left
My tv is no picture but they have sound & power
Posted on May 07, 2008
jerryg50
  • 1667 Answers
SOURCE: Sony KV XA 21M80 Trinitron- HUMMING NOISE AND PICTURE NOT CLEAR
If your set has a humming noise when connecting the cable, call your cable company. There is a ground issue. This can also be a safety issue.
If your signal is PAL, and your TV is NTSC only, you will have to replace the TV with a PAL one in order to properly view the programs.
Jerry G.
Posted on May 25, 2008
  • 132 Answers
SOURCE: STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Posted on Feb 01, 2009
  • 8909 Answers
SOURCE: Sony pre-LCD 32" receives power and directly
You have a regulator problem in the power supply. Possibly capacitors, (tuning).
As a company, I cunducted research on the average life time of a TV.
Rental sets, around 5 years.
Owned sets 6-7 years, before they become uneconomical to repair.
Hope that helpsw.
Posted on Jan 03, 2011
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
I connected my sony DVD player to a 26" sanyo tv. I used the enclosed cable. I plugged the cable in as shown using yellow to video and red and white to audio. Selected video 1 input on tv the DVD...
If you have red, white, and yellow on both DVD and TV it should work. The DVD is obviousy an output so, check your connection on TV. You may find that if you scan through the TV's menu, you will have sound in one arae and picture in another. If you have a DVD in or AUX input on the TV try, and make sure you use the inputs for the respective setting, to hook up there and see what happens. You want input on TV.
Jun 20, 2011 | Sony DVP-SR200P DVD Player
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
DVD picture is pink
check that all leads are pushed in
Nov 29, 2009 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hookup
very simple , just made sure dvd output hooked to the input of your tvs and same color ,jack to jack,you know, yellow to yellow,red to red ,white to white.But I suggest you use a s-video jack(all black). instead of the yellow composite ,or RCA jack,which give you a better picture,and if you have a the component jacks (red, blue , green)on both machine , that will give you the best picture, but remember , you still have to connect the red(right channel,+))and white(left channel,-)cable to have sound coming out from your tv.You will need a s-video cable or component cables for those option I suggested.
Nov 17, 2007 | Sony DVP-NS55P DVD Player
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
