Question about HP DeskJet F380 All-In-One Printer
How do I scan with HP F380 printer?
I just install and check the printer and copier, is working but I couldn't chech the scanning, can you tell me the how to do stap by stap?
Visit http://saksaklombok.blogspot.com to solve this
Posted on Nov 01, 2011
Hp Deskjet F380 All - in - one
Posted on Jun 03, 2009
Please tell me the procedure to scan using my hp deskjet f380 all-in-one series printer
if it installed corectly, you can scan with program adob photoshop, imort from
May 29, 2011 | HP DeskJet F380 All-In-One Printer
My hp deskjet f380 is not scanning.
To scan, you need the HP Photosmart software installed (you can download it from HP at the link below). Start HP Photosmart, then put your original in the scanner and press the "Scan" button. You can scan multiple sheets, when you're done, click "done" and the files will be saved as JPEGs in the My Scans folder in My Documents.
Apr 14, 2011 | HP DeskJet F380 All-In-One Printer
It is a all in one HP F380 series printer. But I have not been able to scan with the printer. I have downloaded and installed the driver but it seems as if the scanner driver is not installed with it.
uninstall the driver with revo uninstaller & then download the full feature driver from hp.com, also make sure u check the present os version, then install it i shud be able to scan
Mar 30, 2010 | HP DeskJet F380 All-In-One Printer
Printer hp deskjet f380
If you have Vista as your operating system, Windows Vista provides a basic set of scanning drivers, also referred to as Windows Image Acquisition (WIA) drivers, that you can use as an alternative to scan a document when you cannot scan using the HP drivers.You can still scan with one of the following methods:
(Click here) workaround
Feb 10, 2010 | HP DeskJet F380 All-In-One InkJet Printer
How do i scan a document so that it can be saved on my pc?
connect the printer to your pc using usb cable .install the driver of the printer (hp deskjet f380 all-in-one ) . after complet the installation one hp solution center named one icon will come in desktop open that one and goes through the process (scan document ...>select where u want to scan ..>scan )
Nov 09, 2009 | HP DeskJet F380 All-In-One Printer
How can I scan the file in pdf format with the help of HP deskjet F380. I purchased this All in one printer fefore last year.
to scan in pdf format you have to install the acrobat writer software in your machine..... if you installed do like this ...
open hp solution center...>scan document .....> it will open one more window in that scan to option select acrobat ............. and scan.....
Nov 02, 2009 | HP DeskJet F380 All-In-One Printer
Scanning a photo
Make sure you have the HP imaging software installed and running first if you dont you can download the Vista version HERE that should do it
Jun 30, 2008 | HP DeskJet F380 All-In-One Printer
F380 hp all in one
This issue occurs if the scanning files are not installed properly. Once search for the hpqscnvw.exe file and try to scan from there and check for the result. If you are able to scan then download scan diagnostic utility from the hp.com and run it. If the issue persists reinstall the software.
May 20, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
310 people viewed this question
Seeker5211
Seeker5211
