Question about NetGear DG834G Router
Cannot login and have reset....
Hello I have a netgear wireless router WPN824v2 i cannot access the login page and have reset router several times and still cannot login in i have tried the admin password password and 1234 and still nothing. All of the lights are green on the front, what am i doing wrong?
  • kpparker77 Jun 02, 2009
    Hi Tualiapz, I used the little hole on the back of the router and pushed it in and held it for about 20secs until the tick on the front of the router lit up. Also I have had it activated awhile ago and it was working but then stopped (so stopped using router altogether)because i didin't realise i had to change the internet settings to fullbridge.(which i have now done) Have only tried to set it up again, could this possibly the cause of the problem that it has been activated before(about 1year ago)
    I'm also not very computer savvy so not sure what you mean by console cable, and what the IP address would be. Sorry Bunty1981 :(
    Hi Myrlex, I meant to say i was using the username as admin and the password as password like it says on the bottom of the router. Sorry i didn't explain myself properly. May i ask what is lynksys password?
  • Tualiapz
    Tualiapz May 11, 2010
    When you said reset the router, did you just turn the power off? or did you use one of the pin holes to reset the whole device?
  • 674 Answers
If you want to access the modem
lynksys password
username: admin
password: admin
not admin for username: and 1234 of password
the default security is,, admin, admin
thanks
Posted on Jun 02, 2009
  • 66 Answers
Use the console cable . By using this u can able to go inside the router and after going inside just give the respective IP and after giving the ip to the router u can access the router by using Internet Explorer .
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
Cant access 192.168.0.1
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Aug 06, 2012 | NetGear WGR614 Wireless Router
Info on how to reset the router
You can factory reset the router using the small button on the back, hold it in for 30 seconds with the power on to the router. This will clear all settings from the router including the password, so you will need to set up the router again after the reset.
Sep 21, 2011 | NetGear WGR614 Wireless Router
I need to reset or find my origional password. Please help. Thanks
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Feb 17, 2011 | NetGear DG834G Router
How do i reset password for netgear router
There should be the reset button behind the router, click on it for about 5-10 seconds.
Jun 26, 2010 | NetGear WGR614 Wireless Router
Would like a set up wizard download for my netgear wpn824v2 router. no cd
from router with ethernet to computer.....then open up your web browser and type in the address bar 192.168.0.1, a pop down login appears user/login= admin, and password- password. click okay. now you should be looking at the netgear config page. there is a button or tab you can click on that says wireless settings, so click it......first is the SSID which probably says wireless or netgear in it.....put in a name you will recognize when searching for your wireless connection......this is the Name of your wireless connection.... then scroll down to wep 64 bit encryption and select it. next, scroll down to key1 and type in a ten digit code (area code and phone number usually works great). leave the passphrase box above key 1 blank. once you have your code typed in scroll down to the bottom where it says apply and click the apply button. now , you need to double check that the netgear saved your new settings, so once the apply click refreshes the page scroll down and make sure its still there,,,,if not write down what the netgear replaced it with. once doublecheck is complete no need to apply again , just close your browser. then remove the ethernet cable, go down by the clock and right click your wireless network icon to view availbel wireless networks,,,, you then should be able to find Your SSID name and click it to then type the encryption in and now your surfing.
Dec 21, 2009 | NetGear RangeMax WPN824 Wireless Router...
Having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the router...press and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : admin....it should work
Netgear address : 192.168.0.1 ( Type in IE address bar to access it )
Regards,
Anup
Apr 06, 2009 | NetGear WGR614 Wireless Router
I got a NETGEAR wireless modem WPN824V2 i can get on the internet through the cable but cant get on through wireless.My wireless switch is on and it says I got excellent srength.CAN anyone can help me...
Thanks for posting. First reset the modem by pressing the reset button, then connect to the admin page of the router, normally the gateway IP (http://192.168.1.1). The you will find the WAN (isp) settings. Enter your login info for your isp and clone your mac address, normally under advanced. __________________
Hope this helps
Mark
Nov 25, 2008 | Computers & Internet
Netgear WPN824v2
If the default username and password is not working you wont be avle to access the router setup page, so the next step that you need to do is tor eset the router and reconfigure it back, to reset it press and hold teh reset button of the router for 15 seconds while the power is ON then after that the default username and password should be working...
Nov 08, 2008 | NetGear DG834G Router
NetGear DG834G Router Logo
496 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
