Question about Microsoft Windows XP Home Edition
Have problem with my Microsoft Windows XP Home Edition, when control panel is open get C:\Windows\Systems32\.Exe'. when I try to open java get same message how do I reslove problem? This is a Dell Dimension E310 Desk Top.
  • 2 more comments
  • dwarren421 Jun 02, 2009
    Have problem with C:\Windows\Systems32\Rundll32\.Exe'. can not fix problem this is Microsoft Windows XP Home Edition. If I click on the control panel Add or Remove file or Java etc. and some other I cons I will get this message.
    Could you make your example a little easier, so I won't make a mistake I am not that good. So the problem is in the registry, can I download and re-install?
  • Tualiapz
    Tualiapz May 11, 2010
    lmao.. fslahmedwho posted the solution below has no idea what he is on about.
    I would not even bother with any of those if I were you....
  • Tualiapz
    can you provide the full error message?
    what do mean by you get C:\Windows\Systems32\.Exe' ?
    Also state how does the error comes up. by clicking or just open some software?
    Sniper:
  • 80 Answers
To fix your error, you need to have your windows XP cd. This issue occurs because of a missing or corrupted Rundll32.exe file. This issue may also be caused by a virus.
To resolve this issue, follow these steps:
  1. Put the Windows XP CD ROM disk in the CD ROM drive.
  2. Click Start, and then click Run.
  3. Type expand X:\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
  4. Restart the computer.
This may not 100% fix your issue but at least its a try.
Posted on Jun 02, 2009
    Sniper:
  • 127 Answers
Just boot your comp in safe my by tapping F8 while booting the comp.
Click Start, and then click Run. (The Run dialog box appears.) Type regedit
Then click OK. (The Registry Editor opens.)
Navigate to each of the keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\ CurrentVersion\RunServices HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
NOTE: All of these keys may not be found on all the systems.
From each key, in the right pane, delete these values if you find them:
SystemSAS system32.exe CMD cmd32.exe
Navigate to and delete the key:
HKEY_Local_Machine\Software\Krypton,
Navigate to the key:
HKEY_Local_Machine\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
NOTE: This key does not exist on all the systems. If you do not find it, proceed to step i.
In the right pane, double-click: Shell
Change the text in the Value data box so that it reads only:
Explorer.exe
HKEY_Current_User\Software\Kazaa\LocalContent HKEY_Current_User\Software\iMesh\Client\LocalContent
In the right pane, delete any values that refer to the C:\%Windir%\UserTemp or C:\%Windir%\User32 folders.
For example:
Dir? 012345:C:\%Windir%\UserTemp
NOTE: "?" in this value represents a number that the worm has selected.
Exit the Registry Editor.
Several of my pogo games won't open
See in the control panel how many versions of Java are installed.Un install all versions if you know no other programs on your machine are Java dependent, then reboot and Install a fresh copy of Java, make sure Java is enabled and automatic update is selected.
Mar 05, 2014 | Microsoft Windows XP Home Edition
Lost my Outlook Express. exe (using Windows XP). How can I download this and can I get all my "saved" folders on my previous account?
Hope you get lucky with this:
Go into your Control Panel and open Folder Options, under the View tab checkmark "Show hidden files and folders" and uncheck "Hide protected operating system files [Recommended]", click Apply/OK. Now go into Windows Explorer and go to C:\Windows\System32\dllcache folder and open it. There should be a copy of msimn.exe there. You can right click it, choose Copy then paste it into the C:\Programs\Outlook Express folder.
if nothing happens then, For futher and any other technical troubleshooting contact, virenderhasanaccount@hotmail.com
Jan 06, 2010 | Microsoft Windows XP Home Edition
Java says fatal error when i try to install on computer. i tried to copy it from external drive on to computer.
I would go to control panel, then "add or remove software". Find Java and then completely remove it. Then go to www.sun.com and redownload the java software and install it again.
Nov 21, 2009 | Microsoft Windows XP Home Edition
Pogo.ui2.awt.e@61ec49 won't let me play games
try updating your java.
look at control panel - java click on the update tab and then click on update now. let it update then reboot and try your game.
If you can't find the java under control panel then you may have to instal java from Sun.
http://www.java.com/en/download/index.jsp
Download and run to install. Check for updates and reboot then try your game.
After all that it if it hasn't fixed it, it can just be a java programming error.
If the game is populaur these usually are fixed very fast. If you keep trying every few days it should get the updated file and your game will work again.
Aug 21, 2009 | Microsoft Windows XP Home Edition with...
Keeps saying java not found
Step 1: Run Pop-Up Blocker Test
To test your browser for a pop-up blocker, just follow the instructions mentioned in the link below: http://www.pogo.com/misc/popup-blocker-test.jsp
Step 2: Run Java Test
To test Java, just follow the instructions mentioned in the link below:
http://www.pogo.com/misc/sun-java/plug-in-test.jsp
Step 3: Run Easy Info - Pogo Edition Test
Download and run EasyInfo_v2_for_Pogo.exe, just follow the instructon mentioned in the link below:http://eapogo.custhelp.com/cgi-bin/eapogo.cfg/php/enduser/std_adp.php?p_sid=wezk7Ltj&p_accessibility=0&p_redirect=&p_lva=10988&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD00MDgsNDA4JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj1_YW55fiZwX2N2PX5hbnl_JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_faqid=10318
Step 4: Update your Java Virtual Machine
You can download the latest version of Java from http://www.java.com. Before downloading and installing a new version, please make sure you uninstall the current version by clicking on Start->Control Panel->Add/Remove Programs. Once the Add/Remove Programs screen comes up, look for the Sun Java entries and uninstall them. Then you can install the latest version from the java.com web site. You should also remove the Microsoft Java Machine by following this method:
  1. Click on the Start menu, then select the Run option.
  2. In the Open: field type in or copy and paste the following text
    RunDll32 advpack.dll,LaunchINFSection java.inf,UnInstall
  3. Then press the OK button.
  4. You will now be presented with a conformation prompt like the one below:
  5. Press the Yes button to start the uninstall process of the MS JVM.
  6. Windows will uninstall the files and then give you a prompt asking whether or not you want to restart the computer. You should press the YES button to allow it to do so.
  7. When the computer has restarted and you are back at the desktop delete the follow folders and directories:
    • c:\windows\inf\java.pnf
    • c:\windows\java
    • c:\windows\system32\wjview.exe
    • :\windows\system32\jview.exe
  8. Click on the Start menu, then select the Run option.
  9. In the Open: field type in or copy and paste the following text: regedit.exe
  10. Press the OK button.
  11. Navigate to the following keys and delete them:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Java VM
    HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\AdvancedOptions\JAVA_VM
  12. Step 5: Run Windows Update Apply all the available updates to Windows by installing them from this url: http://www.windowsupdate.com
Jun 19, 2009 | Microsoft Windows XP Professional for PC
Upgrade software
"wupdmgr.exe"
type this in run instart menu then pres enter.
then update
Mar 21, 2009 | Microsoft Windows XP Home Edition Service...
Sun java problem
Check under Control Panel/Internet Options/ Advanced
Make sure Java section is enabled.
Feb 15, 2009 | Microsoft Windows XP Home Edition
I can't play big fish community games
take off monzilla use www.ccleaner.com tool then remove all old java from add remove then go dl latest one then try k
Sep 20, 2008 | Microsoft Windows XP Home Edition
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
HELP!!!
HI CANDI
  • GO TO CONTROL PANEL
  • CLICK ON ADD/REMOVE PROGRAM
  • REMOVE JAVA SOFTWARE
  • DOWNLOAD JAVA SOFTWARE from http://www.java.com/en/
Nov 03, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
165 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
