Question about HP OfficeJet 4215 All-In-One InkJet Printer
Says "document failed to print" constantly after printing half of 1st page
HP printer/copier/fax--"document failed to print"
  • 66 Answers
First u check the cable of the printer to system connected properly from both end if not then connect properly , after that problem not solved then change the cable and try if the printer is working then the old cable is faulty , if the printer not ok then uninstall the printer driver from system and restart the system then after restarting the system reinstall the printer driver properly by giving right port, after installing restsrt the system . After restarting the system check by giving a print
Posted on Jun 02, 2009
It prints only half a page.... how can i fix that???
Does the print fade out or is the printed page complete, just cropped down? If it is fading out then it is the cartridges running dry, or refilled using the incorrect ink. If it is printing the entire document, just smaller, then under printer properties you can set the page size. (control panel - printers and faxes - right click your printer and select printing preferences) I hope this helps Regards GM
Apr 13, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have HP 4355 all in one printer .Whe I click on print it doent print and takes me to fax sending page Please help
there exist two printer drivers, one for printer and another for fax... may be your machine have the print to fax driver as default hence it takes you to fax page... u can manually select (or make default..) the printer driver to print document on paper... if it does not exist try reinstalling it.............
Mar 06, 2009 | HP Officejet 4355 All-In-One InkJet...
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Oficejet v40xi only prints partial documents then "disconnects"
XP the virus magnet where anything can happen bad, and DOES !
why run 15year old OS.? why not upgrade.?
The Lenovo stinkpad. (was IBM)
why not move the printer to another PC, ? to prove printers bad
is that hard?
even plugged in to any LAPTOP, say with W10
v40xi , as old as 2003, is yours that old?
was even run on old windows 98 back when.
but has HP support up to windows 8.1
try printer on win7 win 8.
is the way to do this, using the correct driver. from HP.com
Mar 29, 2017 | HP WanProbe V-Series Network Monitoring...
Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Dec 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printing error on desktop when printing to 4600dn
try re installing the original software for the printer. sometimes hp drivers get corrupted by either use or anti virus. this normally should fix the problem If it does not please come back
Apr 19, 2008 | HP LaserJet 4600dn Color Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
