Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
ICE MAkER HANDLE PROBLEM
I find it very difficlut to lower the ice maker handle. It seems to be stuck.
  • Whirlpool Master
  • 4,655 Answers
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 02, 2009
Ice machine not making the ice
Almost all ice makers have a on/off switch. I did not see in your answer that you did not checked it.
Assuming the switch is in on, in most ice makers there is an electrical plug that provides power to the ice maker. To check this plug you typically have to remove a couple of screws that anchor the ice maker to the cabinet. After removing these screws, lift out the ice maker until you can see the plug. If it is not plugged in, plug it in.
There is also a bin switch in many model that needs to be lowered in order for ice production to commence. It will look like shiney metallic bail and needs to be lowered. During normal ice production, as ice is harvested the fresh batch will push on the this bail and if it pushes far enough it will cause the controls to stop ice production. Once the ice level lowers and the bail is allowed to lower, ice maker will start making ice again.
Hope this helps
Dec 13, 2014 | Maytag Refrigerators
Ice maker, water panal on side by side refigerator not coming on when depresing handle
The water line could be frozen. Remove the water filter and see if it frozen. Also, see if the water dispenser works with the filter removed.
Sep 09, 2012 | Maytag MSD2572VEW (25 cu ft) Side by Side...
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
Ice maker not working. Refrigerator had been off for 1 week. Now not making ice. There is water coming into the water dispenser but does not seem to be getting to the ice maker,
Hello there
f your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Jul 26, 2010 | Kenmore 21.7 cu. ft. Top Mount...
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Apr 01, 2010 | Viking DDSB483 Side by Side Refrigerator
Fridge and Freezer quit working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
May 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Icemaker does not make ice. Appears no water is getting to maker.
May 20, 2009 | Refrigerators
Ice maker not making ice
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
574 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
