The printer is in excellent condition, single home user, used sparingly. Both black and colour-true colour prints
SOURCE: Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
SOURCE: HP Color Laserjet 5550 not printing duplex
Hi, Check that the printer driver has duplex (double sided) turned on.
That's if u hav not already solved it :-)
Laser Printers that printouts can be smudged usually means the Transfuser (the part that settles the toner onto paper) is not fully functioning or damaged. Simply replace it and it should be back to normal. However, these Transfusers are quite expensive. So you may be better off to get a quote for a new one if out of warranty.
SOURCE: Cannot get the printer to print colour
Try This :
Click On Start >>> Control Panel >>> Printers and Faxes >>> Right Click on the Printer Icon >>> Click on Properties >>> Click on Printing Preferences >>> Click on the "Color" Tab >>> Under color options Select Print in Colour >>> Click on Apply and click on OK.
Try to print in Colour.
Regards Soumajit
