Question about AcerScan 320P Flatbed Scanner
Error Message "Set Parameters Failed"
Installed Acerscan 320U using compatibility wizard on NT and I am getting the error message "Set PARAMETERS FAILED"...HELP PLEASE!!!!!!!
SOURCE: Acerscan 320u installation disc
Look here http://www.benq.us/support/downloads/index.cfm?productline=9
Posted on Apr 15, 2008
micromaster
  • 3614 Answers
check and download HERE & HERE
Posted on Oct 17, 2008
SOURCE: Set Parameters Failed
I have the same problem with my Acerscan 620U flatbed scanner which I have used for years, even with XP home SP2 & 3, after I reloaded the Operating system on the same machine, (after a crash) It would not work properly, so I searched for new drivers and softwareafter not finding anything useful here, I went to driverguide.com and found 2 files for the 620U. A zipped file containing the original (Win 95-98) install disks - 2Megs, (pasted from Driverguide);
Model Acerscan 620U Manufacturer Acer info_icon.gif Operating Systems Win95, Win98 Device Type Scanner File Name disk1and2.zip
Uploader Notes This is the install softwarefor the AcerScan 620U, which is the USB model. I wasn't able to find itanywhere on driverguide.com and when I tried to download the latestversion off of the Acer website it didn't work, crashed my graphicsprograms. This one worked perfect.How it works
Unzip disk1and2.zip.
This will give you disk1.zip and disk2.zip
Unzip disk1.zip to a folder called disk1.
Unzip disk2.zip to a folder called disk2.
Runthe 'Setup.exe' file in the 'disk1' folder - halfway through it'll askyou where 'disk2' is. browse to wherever you've unzipped disk2 andthat's it!
I also downloaded a 14 meg file "mirascanv403u10.exe" (<a href="http://members.driverguide.com/driver/detail.php?el=1&driverid=128406">Acer AcerScan 620U Driver</a>) which is supposed to work with W95-98, ME, W2000, XP (with mixed reviews)and Mac-OSX, I haven't tried either of these yet although I will try the Mirascan file first. For many users the difference may be that when setting up an XP machine you have the option to use a FAT32 file system or an NTFS partition, it may be that the software doesn't work with the NTFS partition/filesystem.
If you send me a request to lrpett@gmail.com I will send you either or both of the files as an attachment until Jan 10 2009 then I delete them, (or you can get them from Driverguide) I'll also let you know what worked for me.
Posted on Dec 27, 2008
SOURCE: installing Acer AcerScan 320U Flatbed
any driver that works with this scanner on a ibook?
Posted on Jan 22, 2009
SOURCE: ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Posted on Mar 26, 2009
Tip
STOP: c000021a {Fatal System Error}
This article is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Technical Support.
When you use a server or a workstation that is running one of the operating systems that is listed in the "Applies to" section, you may receive the following error message: STOP: c000021a {Fatal System Error}
The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000)
The system has been shutdown. Note The parameters in parentheses are specific to your computer configuration and may be different for each occurrence.
CAUSE:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Resolution will not fit here so kindly go to:
http://support.microsoft.com/default.aspx?scid=kb;en-us;156669
I hope it helped you. Rate for this information will greatly be appreciated. Thank you!
on Jan 20, 2011 | Computers & Internet
I have windows vista home premium and an old Microtek scanner than will not install the scan wizard with error message: USB scanner does not support windows NT now. Please help as everything else...
I don't think you have a chance, but you could try Compatability Mode & Installing as Administrator. To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu. Select the Compatibility tab: Set it for "XP SP2"
Feb 03, 2010 | Office Equipment & Supplies
Router setup gets Error 302 message
Old configuration parameters are lost. Check with your service operator for a fresh config details to enable the router in gateway mode.
Oct 18, 2009 | Computers & Internet
Installation of yahoo messenger error
I think you will need to upgrade your windows installer version.....download it from Here run it and now try ...hope it will work...Good Luck
Sep 25, 2009 | Yahoo Messenger
Webpage error details User Agent: IE/8.0... 4Code: 0 URI: http://mca.gov.in/DCAPortalWeb/dca/js/homepage. Unable to login using IE but able to login using Google Chrome. Please advise reasons.
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; Trident/4.0; GTB6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729; msn OptimizedIE8;ENUS)
Timestamp: Sat, 16 Jan 2010 23:49:28 UTC
Message: 'DOM' is undefined
Line: 33
Char: 88
Code: 0
URI: http://www.facebook.com/?ref=home
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
Line: 0
Char: 0
Code: 0
Jul 18, 2009 | Microsoft Internet Explorer 8
Try to type my username and password in and error message shows
hi there hey it looks to me like you may need to go to device manager and uninstall the device and than turn off the computer and reboot the computer and you will see the new hardware found pop up on the taskbar just let it reinstall it and it will tell you that the device has been installed and is ready to be used now you should be able to log onto it as normal . best regards mike
Jan 14, 2009 | Dell Dimension 4600 PC Desktop
I have a Pixma MP500 Canon printer. The error message coming up is error message # 5200. This is not an error message I can fix. It is not listed in my User's Guide. What is the problem?
Hi affrench,
Your problem in all likelyhood is print head temperature. The temperature at your print heads has exceeding the allowable parameters set forth by your software and manufacturer. If your printer is under heavy use loads this could be why you are getting this error code. Take it easy on the old boy, after all its only a machine, lol. I hope this helped.
Thanks for using FixYa.com
Sincerely, cyyyd7
Oct 09, 2008 | Canon Office Equipment & Supplies
Sep 07, 2007 | AcerScan 620U Flatbed Scanner
AcerScan 320P Flatbed Scanner Logo
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
