Question about Sony PSP (Piano Black)
Configuring psp?? how do i configure my psp??
    Problem Solver:
  • 15 Answers
In what respect?
custom firmware?
Posted on Jul 05, 2009
How to fix my psp 2004 problem the game could not be started (80020321) pls help,
This error is appearing because there is a setting in the hidden configuration menu that is set to require a UMD game disc to be in the PSP when it attempts to load.
Turn off the PSP, then hold the R button down while turning on the system. You will be in the Recovery mode/Configuration menu. Choose configuration, then go to the 5th option, and press X once. This will switch it to "NO UMD". Then press X on "Back", then "Exit". Once you restart you should be able to load the ISOs, CSOs etc. without getting the 80020321 error.
Hope this helps you!
Mar 03, 2011 | Sony PlayStation Portable (PSP) Slim...
PSP Update Error
ok i got it your system configuration is incorrect just do that go to system setting and check out the configuration setting carefully and it will be done.
Dec 06, 2007 | Sony PlayStation Portable (PSP) Console
Tip
PSP Firmware 3.71M33-2 Diagram installation.
This article will explain a diagram of PSP CFw 3.71 installation. I have provided this document as a guide to helps PSP Users get started for installation CFw 3.71M33-2 with 1.50 kernel Addon2 on both PSP, Fat and Slims. here's a simple steps to find out.
Q:How do I know what version of the firmware I have?
A:Follow this, <b>Version check :</b> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP.
Q:How do I boot into "Recovery Mode",?
A:Do a full turn off (hold power button >5sec) and hold the "R-trigger" while turn on the psp.
Q:How do I know what kernel of game folder configured.?
A:Do this via "Recovery Mode" >> "Configuration" >> "game folder homebrew (currently: 3.xx kernel)"
Q:How do I activated the plugin No-UMD of CFw M33.?
A:Do this via "Recovery Mode" >> "Configuration" >> "UMD Mode" >> Select currently : "M33 Driver - No UMD". Any 4 option umd mode you can select, we recommended to select "Sony NP9660" for most games compatibles.
Q:I getting a blank screen/BSOD when booting my PSP, after downgrading my psp with pandora's?
A:Press "Bright" button on PSP, You will get a message for telling You to press "Circle" (O). Do it, and reenter your settings. Reboot your PSP if necessary.
Source : http://e-arena.blogspot.com/2007/11/psp-firmware-371m33-2-diagram.html
Hopefully this helps..!
on Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
My old psp keeps displaying : the system configuration of this psp system does not appear to be correct. the update cannot be started. contact technical support for assisstance. (DRNFFFFFFD7) my current...
turn off ur psp,( hold d power button up for 3 sec.) den, hold d "r" button n den turn it on, don't leave d R button until psp starts. dis process will take u to d psp configuration settings.
Jan 03, 2011 | Sony PlayStation Portable (PSP) Console
How should I do internet in PSP
To install an internet on your PSP you will need an internet access, check with provider in your country , go to your menu on your game and configure it manually, instruction on how to configure can be found here Manual On Games Solutions, Good luck....
Oct 27, 2010 | Sony PlayStation Portable (PSP) Console
When i try to do autorecvry on my psp. And the psp restarted error "80010002"
Hi,if you are having the error code "80010002" follow the solution below ;
shut down your psp, then start it up again holding the Right Trigger to activate recovery menu.
go to Configuration, and use no umd.
then go to Advanced, then Advanced configuration, then disable both of them.
This will definitely solve the problem,good luck!!
Jun 22, 2010 | Video Game Consoles & Games
My psp wont connect to my router and i have the same wep key password in is this a "firewall" problem?
What exactly message you get when u try to connect your PSP. However, here is simple few steps to configure your PSP, just see if u have missed something. (Router Configuration) open your browser and type 192.168.1.1 and use admin as username and password.Apply your PSP MAC in the routers. for this go to Parameters > System> PSP Information in your browser of PSP. (PSP Configuration) Go to Settings >LAN>Infrastructure Mode>New Connection>Scan> now select the IP address of the Router and enter the WEP key which is written the router. Now you should be able to do Custom>Automatic>Do not use . Remeber you only select Do not USe if you dont browse through your PSP. Now Enter and this will InshahAllah solve your problem.
Regards
Jun 09, 2010 | Actiontec GT704WG Wireless Router...
The games at my psp runs very slow but for other features its fine, but before i try to repair the error code 80020321, please advice
This error is appearing because there is a setting in the hidden configuration menu that is set to require a UMD game disc to be in the PSP when it attempts to load. Turn off the PSP, then hold the R button down while turning on the system. You will be in the Recovery mode/Configuration menu. Choose configuration, then go to the 5th option, and press X once. This will switch it to "NO UMD". Then press X on "Back", then "Exit". Once you restart you should be able to load the ISOs, CSOs etc. without getting the 80020321 error.
the answer from: http://wiki.answers.com/Q/How_do_you_fix_the_PSP_error_80020321
Mar 25, 2010 | Sony PlayStation Portable (PSP) Console
System configuration error (DRNFFFFFFCD) 5.50
You need to fix IDStorage... Google for Despertar del Cementrio 8 fixing idstorage
Sep 21, 2009 | Sony PlayStation Portable (PSP) Console
My analog stick is not working on the psp menu
you really cannot use your analog stick if you're at the menu. its really like that. i've had my PSP for years and i believe that there's no mod or configuration to do that. Sorry mate.
May 01, 2009 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
