Question about OCZ ModXStream (OCZ780MXS) 780-Watt Power Supply
-5v is sitting at -8.48
Unfortunately I don't know to much about power supplies, at least specifics.
Ijust installed a new PSU and according to speed fan my -5v line issitting at -8.48v. I'm relatively certain this isn't normal. My -12vline is sitting at -0.43v and my +12v is at 12.54.
It could just be something wrong with speedfan, but i can't say for sure.
It could also be something wrong with my motherboard.
I'm not sure about my old powersupply, unfortunately that could be a royal pain in the neck to test.
I'm pretty sure there is something wrong with some of my ram Slots, but i'm pretty sure that has nothing to do with it.
If anyone can shed some light on the situation that'd be great.
System
Windows XP sp2
Gigabyte GA-MA69VM-S2
OCZ 1G PC2 6400
AMD Athalon X2 4000+
Sapphire Ati Radeon X1650Pro 256M
Seagate Barracuda 7200.8 300G
16 NEC DVD-+RW
Belkin wireless card
OCZ ModXStream 500W psu
  • 1,056 Answers
If you were measuring the voltage right then it seems like a power supply problem. Make sure you are measuring voltage potential with respect to common ground. Meaning the black wires on your meter probe is on the metal body of the PSU.
Posted on Jun 28, 2009
Is there a protection mode for this lcd visio tv that can be removed for this tv to come on ?
Hello Donald the first thing I would like to Know what the model number of your TV is. But that's ok if you have a external power supply you could try this .Make Shure your TV is not pug In to the Ac outlet. We are going to see if you have a short or a load on your 12v line. Ok you wont to unplug the 12v source from the power supply board. Fine out what pin is the 12v's. Connect your external power source to that pin, apply the 12v and see if it is drawing to much current. If so check the boards for any very hot items. If you have a problem on the 12v line. This will find the part that is loading it down. This is the old way of finding a load on a power source. I hope this will help some. P.S make Shure there is no AC connect to the TV as you do this test and you have the plug off of the power supply board before using the external power source.
Jan 01, 2015 | Televison & Video
Power supply
The power supply is located in the back of the machine on the left hand side. It is part of the electronics module. It produces 24V, 5V, 3.3V and -15V.
Feb 05, 2014 | HP DesignJet 1055cm InkJet Printer
ATX motherboard connector pin out
Black=0V(GND)
Yellow=12V
Red=5V
Orange=3.3V
Purple=5Vsb(everytime on)
Gray is PWRGOOD or PWROK(pwr=power) must be at 5v
White=-5V(optional)
Blue=-12V
Green is PWRon must be connected to a black wire to turn on the PSU
Nov 16, 2012 | Enhance Technology ATX-1123B, Enhance...
DPS-260lp
It could be your PSU(Power Supply Unit) or your motherboard
to test your PSU use a voltmeter
1-Unplug PSU from motherboard and all unit in the PC
2-Put a small wire between black(GND) and green(PSon) wire
3-Test voltage
Orange is 3.3V
Red and purple is 5V
Gray is PWRGOOD(or PWROK) it must be at 5V
Yellow is 12V
Blue is -12V
White(optional) is -5V
Nov 11, 2012 | Computers & Internet
Board will not start
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set up to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
Aug 18, 2012 | ASUS P4P800-VM Motherboard
System dead
Hi Fr.David
You mention '..info on BIOS..'
Is your BIOS (or anything) displaying on the screen?
If screen is also dead, then your PSU 5V (red) section is suspect.
As the fans are fanning then 12V DC (yellow) is still OK.
To check your PSU, unplug & disconnect all power connector cables (note where they go, esp the M/Board supply).
Some PSU's have a green 'signal good' wire which to test must be grounded with a paper-clip etc to black.
This tells the Power Supply Unit to start up.
Black is common negative, Yellow 12V positive, Red 5V positive.
I'm positive.
I hope your test results are not too negative. ;)
Hope this helps.
Clive.
Oct 28, 2017 | Mach Speed (MSNV-939) Motherboard
Is there a comptable power supply to replace FSP250-60HEN
Although ATX power supplies conform to various specification guidelines, there is not, unfortunately, a standard ATX power supply. To find a suitable replacement power supply for your machine, we would recommend that you have the following information to hand when making your purchase:
- You will require a PSU with a 24-pin ATX connector, SATA power connectors, and a 4-pin 12V motherboard connector
- Make a note of the wattage of your existing PSU
- Make a note of the external dimensions of your existing power supply
- Be aware that your PSU has a power connector for speakers. Most PSUs do not have this, so you may need to purchase a separate power supply for your speakers.
So it is a slight variation to a standard ATX power supply. If you are not using the speaker power off the power supply, then any standard ATX power supply will work for you
Feb 20, 2010 | Computers & Internet
Polaroid " 3211 TLXB red light no power up?Ive checked for Bad Caps,on the main power supply.I found none,that were swollen or leaking.It looks good.I checked volltage out to volltage inverter.all the out...
hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
Oct 12, 2008 | Polaroid 3211TLXB 32 in. LCD Television
No Power Up State
CHECK YOURE POWER HOOK UP ON THE BOARD MAKE SURE THEY ARE HOOKED UP ON THE RIGHT ONE IF THEY OR OFF ONE PEG IT WILL NOT POWER UP
Aug 21, 2007 | Dell (58GGC) Motherboard
OCZ ModXStream (OCZ780MXS) 780-Watt Power Supply Logo
176 people viewed this question
Top OCZ Computers & Internet Experts
David
David
Victorman
Victorman
Stan Skaggs
Stan Skaggs
Are you an OCZ Computer and Internet Expert? Answer questions, earn points and help others
