Magellan Roadmate 1200 Car GPS Receiver
Problem for Magellan Roadmate 1200 Car GPS Receiver
Magellan roadmate sd card error
By jcam1136 on Jun 02, 2009
My gps unit says that my sd card is removed but it is not. It has worked perfectly for about a year and now it reads this error message and won't let me reset it or anything else.
Same Problem
Aug 29, 2009
-   nothing happens it still has the same message
-   m_khlf
Solution #1
posted on Jul 17, 2009
Somewhat Helpful)
stephen_sher
Rank: Guide
Rating: 83%, 9 votes
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
  1. Remove your SD card from your GPS
  2. Insert your SD card into an SD card reader or connect it to your PC
  3. Wait for windows to go through it's process of discovering your the "removable storage device" your just connected (see step 2)
  4. (This step may be different depending on what version of Windows you are using or depending on how you have your OS laid out). Look at the lower right hand corner of your desktop. There should me a small icon there with a green circle and a check mark. It looks like this...
  5. Click that with the right mouse button.
  6. It will say "Safely Remove Hardware" - Left click that message.
  7. A window will pop up allowing you to select your SD card and "Safely Remove" it (it will have a letter name like "drive F" for example).
  8. Wait for the windows to tell you it is ok to remove your hardware - then remove your SD card form the PC
  9. Make sure your GPS is turned off.
  10. Insert the SD card into your GPS.
  11. Turn on your GPS
  12. That's all! I hope I was able to help.
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Magellan Roadmate 1200 Car GPS
Questions and Unsolved Problems for Magellan Roadmate 1200 Car GPS
Do you recommend Magellan Roadmate 1200 Car GPS Receiver?
Answer
Answer
I dropped my Road Mate 1212 and now all I get is a white screen, the computer still works. Can the... (More)
Answer
show only SysView and frozen Magellan roadmate I try to turn off and on but don't work
Answer
my roadmate 1200 will not seem to hold a charge even when plugged into the car. how can i fix it?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Devices Experts
Top GPS Device Repair
(408) 298-8188
Auto Nav 2000 Plus, Inc can repair most portable...
Auto Nav 2000 Plus  IS YOUR ONE Stop GPS Store
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
