Question about E-Machines eMachines Desktop PC
E machine t2482
Monitor says no signail I have an emachine 2008 EL1200-06w, screen says no rgb signal, harddrive won't power on at all, i connected blue monitor cord to other running tower, and screen is on now. So it's the motherboard, not the monitor; i opened it up and the caps look fine and not raised up or leaking. I just bought new power supply, and it's in the wall, not power strip. There's no video card either. Any suggestions?
    Problem Solver:
  • 19 Answers
Try changeing the RAM and if that dosent work try the processor
Posted on Jun 02, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I am getting a no signal message on my monitor
Don't worry just reset of your bios default settings and check it now :)
May 14, 2010 | E-Machines eMachines Desktop PC
check the cable connections or replace the vga cable
Mar 25, 2010 | E-Machines eMachines Desktop PC
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
Emachine light, fan and harddrive come on only.
Please check the cable between monitor and computer and make sure everything is properly connected. try unpluging and reconnect it.
Thanks,
CF
Jun 25, 2009 | E-Machines eMachines Desktop PC
My EMachines T2482 will not power up properly. The fan comes on, but the monitor remains in the sleep mode, and as far as I can tell, no POST is occurring. The ring around the power button remains dark. It...
Did you remove the CMOS battery and move the jumper on the systemboard to clear the CMOS? After a few minutes or so, put the jumper back and power on the machine. If it powers on fine, you can turn it off and put the CMOS battery back in.
Jun 06, 2009 | E-Machines eMachines Desktop PC
Monitor will not work
its your monitor cable or video card problem not your monitor. check your connections to video card and monitor.
Apr 04, 2009 | E-Machines eMachines Desktop PC
Emachines T2482
Could be a video card failure or a cable problem. This could also happen because the motherboard failed if you have integrated video. Unfortunately your going to have a tech onsite to repair the issue. That is, unless you want to install your own video card which would probably fix the issue.
Jul 08, 2008 | E-Machines eMachines Refurbished EMA...
E machine t2482
check pins some time one of the pins on cable can push through or come out if one is missing it will not work quick way to check is if possible connect to another running tower.
Oct 04, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
178 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
