Question about Dell Inspiron 2200 Notebook
Sound i cannot get any sound .can't find my volume
    Problem Solver:
  • 6 Answers
Click on start click Control Panel click on Sounds and Audio devices make sure the Mute box is not checked and the Volume is all the way up then click the Audio tab click the frist Volume tab and turn all the volumes all the way up if this did not fix your issues you may need to check your drivers
Posted on Oct 24, 2007
I have lost my sound on my desk top pc how do i retrive it bk again
maybe you selected the wrong sound driver. go to control panel. go to sounds, speech, and audio devices. go to sounds and audio devices. go to audio. sound playback, check the device and if diffrent change it and see if that works.
your main volume on all channels where droped. some applications can cause this to happen.
go to start. all programs. go to accessories. go to entertainment. volume control. ensure the volume is up on there. Then if it has it on your volume controll. click on speaker volume that is over top the main volume controll. and make sure your computer speakers didn't drop volume.
make sure the mute is not checked
Oct 25, 2010 | Computers & Internet
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Yes sound problem pls helo me now
From the Taskbar located at the bottom of your computer click once on the "Volume" icon.
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Right click on the "Volume" icon.
Select "Open Volume Control."
Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW Synth (short for synthesizer), CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
Right click on the "Volume Control" icon.
5
Select "Sounds and Audio Devices Properties."
Under the "Volume" tab, slide the "Device Volume" indicator to High.
6
Under the "Speaker Settings," click on "Speaker Volume."
Slide the "Left" and "Right" volume indicators to "High."
7
Click "OK." If this does not fix your sound issue, proceed to step 8.
8
Go to the "Hardware" tab and select the "Driver" tab.
9
Make sure you are connected to the Internet and then, Click on "Update Driver."
10
After the driver has been updated, Click "OK."
11
Exit.
Thanks.
Oct 10, 2010 | Computers & Internet
No any sound from the pc
Step 1
From the Task bar located at the bottom of your computer click once on the "Volume" icon.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Click "OK." If this does not fix your sound issue, proceed to step 12.
Step 12
Step 13
Step 14
Step 15
Step 16
Step 17
Exit.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 01, 2010 | Intel DG31PR Motherboard
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
HP Pavillion dv 8000 no sound
check the volumes on sound driver.., also check maybe the master is muted ...if any of these won't work ..check wave volume also ...or reinstall the sound driver ....
look that when you double click the volume in trey system ( bottom right ) you get the full volume manager ..
if those would not fix the issue...uninstall the sound driver and reinstall it ..I assume you have the installation cd ..or the driver on disposal
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Ring volume too low
All you need to do is goto Tools and Settings/Sound Settings/Ringer Volume
Apr 03, 2009 | LG KC910 Renoir Cell Phone
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Volume
Hi the volume is just a big fuzzy sound. You can listen to anything. Mute button does work and volume adjustment does work. No Sound at all other than fuzzy sound.
Jan 07, 2007 | RCA 32F531T 32" TV
Dell Inspiron 2200 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
