Nikon S205 Digital Camera Logo
A
Anonymous Posted on Jan 24, 2014
TV video locked - Nikon S205 Digital Camera
When I try to use a remote, the tv is not working and it saying keypad locked on the screen of Harwa.
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
How do you remove keyboard lock from harwa tv model ...
Fixya https://www.fixya.com > Forum > Televison & Video
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 ...
I have a harwa tv I dnt have a remote and is - Televison & ...
Mar 12, 2018 - For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on ...
https://www.google.com/search?q=Harwa+television+keypad+locked+on+the+screen
Unlock child lock on Aiwa television please?
How do I take child lock off my TV?"
How to Remove a Child Lock On TV
  1. Get the TV remote control and push the "Menu" button and select "Options." ...
  2. Select "Child Lock" from the "Options" list. ...
  3. Choose the "Remove Child Lock" selection. ...
  4. Enter the four-digit code that you used when you activated the child lock feature.
More items...
How to Remove a Child Lock On TV - Techwalla
How can I set key lock off on my skyworth tv? All the buttons are not working.
http://www.nekkedmeter.com/news-skyworth-tv-how-to-unlock-339.html#:~:text=Press%20%C3%A2%E2%82%AC%C5%93LOCK%C3%A2%E2%82%AC,factory's%20initial%20password%20is%200000.
SOLVED: How can i unlock the child lock of skyworth tv set ...
Jun 25, 2013 - Turn on your TV. · On the remote, press the Menu button. The Set-Up Menu appears. · Scroll to the Key Lock function and set function to Off. · Press ... 1 answer
SOLVED: How to Unlock panel Key skyworth LED TV Model ...
Dec 26, 2012 - How to Unlock panel Key skyworth LED TV Model 32E65 Lock Panel ... down cursor to select "panel lock" then select right cursor to switch off ...
Videos as well
https://www.google.com/search?q=skyworth+tv+key+lock+off
2answers
Help unlock child lock on tv
You need to have child lock code! Maybe has factory default Look manual. Sometimes factory reset overides child lock. Not sure about your model though.
PLEASE COMMENT, I'M INTERSTED TO KNOW
2answers
Child locked on my tv
Possibly, you will need an original remote to disable or turn off this feature. And some child lock can be accessible through neither MENU of your tv or remote. Check CHILD LOCK option to remove it. If it is a screen lock type of CHILD LOCK feature of tv (a Blue Background display a LOCK icon) and your original remote is lost, try a universal remote for you to possibly unlock it. Thanks for using Fixya.
My sony bravia 40'' TV video in 1 and 2 is showing lock, how can i go about it.
try to reset tv from service menu sony service menu display 5 vol+ power from remote and see the reset menu and reset whole tv functions.
1helpful
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Video input
There may be a child lock feature on your set but you would not get sound or picture. If you can not get a picture from the video input jacks and the set works fine other wise then this - sounds like a problem with the Video switching circuits inside your television. I would refer this type of repair to a qualified technician.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
