Question about Konica Minolta PagePro 1300W Printer
Error Light Blinking
The error light is slowly blinking, the green ready light is on but not blinking. Ive checked the printer cable, turned printer on & off, have paper in the tray, ive checked the manual (this isnt on the troubleshoot list) Can you help me with this problem as it takes ages for the printer to actually print what i need. & why is the error light blinking?? thanks Sharon I am having the same problem! Does anyone know what is wrong?
  • 214 Answers
SOURCE: Error
pleas install status monitor, that will tell you whats wrong.
Posted on Jun 19, 2008
whytfang
  • 170 Answers
SOURCE: Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Posted on Mar 25, 2009
SOURCE: pagepro 1350W will not print.
You have to see how the led is blinking and to compare with the table that explains every blink what means. If you don't have this table, contact me and I'll send it to you.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Posted on Aug 23, 2009
SOURCE: Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
Posted on Sep 03, 2009
SOURCE: says ready, error light blinking, vertical non-print line
All four toner lights blinking
it could be that you need to replace all the toners. I do not own this kind of printer, but if it is the same as my inkjets, you have to replace all empty cartridges or it still wont work. try replacing the other toner and see what happens.
Nov 08, 2013 | Konica Minolta Magicolor 1600W Printer
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
HP4550 - 49.00FF service error
Turn off the RAM disk on the printer.
Follow these steps:
Troubleshooting steps
1.
Verify that the formatter light is blinking or steady. If the formatter is blinking, it is functioning properly and probably does not need to be replaced. If the formatter light is not blinking, proceed to Step 2.
2.
Turn off the printer and unplug the power cord.
3.
Remove the HP Jetdirect card, third-party device, hard disk, parallel cable, or IFR cable from the formatter if one is installed.
4.
If the error continues with accessories removed from the formatter, perform a cold reset on the printer. Ensure the HP Jetdirect card is not in the printer during a cold reset or the card settings will be changed back to default settings. To perform a cold reset, do the following:
1.
Turn on the printer.
2.
Watch the control panel.
3.
When the memory starts counting, press and hold the green (Select ) button.
4.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE .
6.
Press (Down Arrow ) button once. The control panel will display COLD RESET
7.
Press (Select ). The printer will perform a cold reset and then continue its power-on sequence.
5.
If the printer comes up to ready, print a Configuration page. If a 49 error occurs from printing internal pages, continue on to the next step.
6.
Turn the printer off and unplug the power cord.
7.
Remove the eight screws around the formatter.
8.
Remove the formatter. See Figure 1.
9.
Reseat the firmware and memory modules on the formatter. Check for any DIMMs that are non-HP and remove them. Non-HP DIMMs are not supported by HP and may cause this error. Replace with HP DIMMs, if necessary.
10.
Reseat the daughter (interconnect) board. The daughter board is connected to the formatter behind EIO slot #1. To release the daughter board, push in the black retaining tab underneath the formatter then lift up the one side of the daughter board.
11.
Reseat the daughter board.
12.
Install the formatter.
13.
Turn the printer on again.
14.
If it comes up to READY , print a configuration page. If a 49 error does not appear from printing internal pages, or at power up, continue to the next step.
15
Install the HP Jetdirect card and hard disk before installing the formatter. Verify that each device is properly seated.
16
Test any EIO devices, by turning off the printer, installing each device separately, and printing a Configuration page. Repeat for each EIO device.
17
If the 49 error occurs with any EIO device installed, replace that EIO device.
Oct 05, 2010 | Computers & Internet
Green and orange light is still stable and big green light is blinking
Hello
Hello, you name the error really is not on the list, the more like these and here is what it says to do. A greeting and let me know if you have been useful
Formatter internal RAM or ROM error Light pattern 3 LIGTHS ON, STABLE Formatter internal random-access memory (RAM) or read-only memory (ROM) error. Action
  1. Unplug the printer and plug it back in.
  2. Unplug the printer, remove any optional memory, and turn the printer back on.
General fatal error Light pattern 3 LIGTHS BLINK DescriptionGeneral fatal error. Action
  2. Disconnect the I/O cable and print a self-test page. If the self-test is successful, reconnect the I/O cable.
Light pattern: 2 little light stable and big light off
Motor malfuntion. contact hp
Apr 05, 2010 | HP LaserJet 1300 Printer
Slow blinking error flashing
Jul 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
All Lights Blinking Fast
You can try add that printer again.... from Printers and Faxes!!!!
Mar 25, 2009 | OKI C3400n Laser Printer
Green Orange
error cable
After a few seconds
turn on the printer
change to a lower
resolution.
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
Says ready, error light blinking, vertical non-print line
Aug 13, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta PagePro 1300W Printer Logo
91 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
