I have a problem...I am connected to the internet however whenever I open the Internet Explorer or any other browser it does not work. Only when I open the browsers using intranet, they will display, how can I fix the problem?
Going to assume you are using IE as your browser. Ok open the browser and i want you to click on Tools on the top of the browser. a drop down menu comes down and now select Internet Options. Now a Internet Option box opens with lots of tabs on top. OK select the one that says Connections. OK at the bottom it has a button that says LAN Settings. OK uncheck everything and make everything clear. Hit OK. This should take you back to the Connections tab and now I want you to hit Setup and go through the wizard.
Rate this plz
I can't believe this...it worked!!..thank you so much for your time and help!!!!..
Hi, sorry to bother you again, but somehow, once I restarted the computer, nothing worked again. Furthermore, whenever I turn on the computer, it says that VAIO SAT SURVEY EXE stopped working and VAIO CARE stopped working...maybe this has something to do with the intranet and internet problem. Thank you so much for your help!
are u using Internet Explorer?
