Home | Dell | Axim X30 Pocket PC | Dell Axim X30 int...
Dell Axim X30 Pocket PC
Problem for Dell Axim X30 Pocket PC
Dell Axim X30 internal backup battery
By PegB on Oct 23, 2007
The internal backup battery needs to be replaced.  Can you tell me where to purchase one and how do I install it?
Thank you in advance for your support.
PegB
Same Problem
May 26, 2009
-   My Axim x30 has just simply died.When I charge it; it fails later on and the information is scrambled or just a series of blue lines.
Do I need an internal battery replacement or do I have a bad card or maybe a bad charger????
Has anyone else had this problem and are the parts accessible online or with Dell?
Thanks alot for your help.
TEM-   TMAC145
Feb 06, 2009
-   Hey, here's an idea. How about someone answer the question? How do you install the battery? -   Guest
Sep 07, 2008
-   Can't locate backup or internal battery-   Guest
Jan 04, 2008
-   ON MY DELL AXIM X30 HAD BACK UP BATTERY LOW ICON. REPLACED INTERNAL BATTERY. CHARGED UNIT ON CRADLE WITHOUT MAIN BATTERY INSTALLED STILL GET BACK UP BATTERY LOW ICON.-   Guest
Dec 26, 2007
-   My Axim X30 doesn't work with battery. Only works with outside power conncection. It has been showing internal back battery needs to be replaced, Not showing anymore.-   Microcrowns
Best Solution
posted on Mar 06, 2008
Helpful)
Beaker 60
Rank: Apprentice
Rating: 96%, 6 votes
Try this web site:http://www.pdasmart.com/aximpartscenterx3.htm?tp=CONTINUE+SHOPPING
Was this helpful?
Yes
No
Solution #2
posted on Dec 27, 2007
Helpful)
Microcrowns
Rank: Apprentice
Rating: 89%, 4 votes
I could not find the internal back up battery after removing back cover. Where is it?
Was this helpful?
Yes
No
Solution #3
posted on Jun 25, 2008
Helpful)
kdoyle_mi
Rank: Apprentice
Rating: 88%, 8 votes
The internal back up battery is a small circular battery (approximately 1/2 inch diameter) which resides under the mother board of the PDA. It has a 1/8 connector on the top of the motherboard. Unfortunately you need to take the entire casing apart to get to this battery as well as removing a small ribbon cable to pull up the motherboard for access. The battery can be purchased at PDASmart [http://ww6.aitsafe.com/cf/add.cfm?userid=8046938&product=AX92-Backup%20Battery%20for%20Axim%20X3%20Series&price=20.00&return=www.pdasmart.com/aximpartscenterx3.htm] for $20.00 US.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Nov 03, 2007
Somewhat Helpful)
phaedrus
Rank: Master
Rating: 83%, 19 votes
batteries are cheap on EBay--around $10. You can get the regular or extended life battery (which might not fit a case like the rhino-skin). I definitely would not get one from Dell--too expensive.
Comments:
Nov 03, 2007
- The internal battery requires opening up the case and shouldn't be too hard to install.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on May 20, 2009
Very Helpful)
gaidin1
Rank: Apprentice
Rating: 100%, 4 votes
Underneath the little rubber stoppers on the back of your unit are the screws to remove the backing. You then need to remove the board and on the front side of the board (the side with the screen on it you will find your battery. The battery cable goes to the back of the board. All of these pieces are push in so no soldering is required. Then replace.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #6
posted on May 08, 2009
Very Helpful)
Stimulas7
Rank: Apprentice
Rating: 100%, 15 votes
I like PDAs a lot, and my own is no exeption. What I don't like however, is when they stop working due to being neglected over longer periods of time. My trusty ol' X30 have unfortunately seen declining use ever since I stopped working and went back to school, and sometime last fall/winter I managed (don't ask me how) to unplug the power cable from the cradle. So there it stood, with no power, til about last week when I tried to power it up again.
After I ran through the initial setup in Windows Mobile 6, I was greeted with a red dialog telling me that the backup battery was critically low and needed to be charged. So, I left it charging overnight hoping that would fix it up. No dice. The battery showed up as "Abnormal" in the power settings dialog, and running the diagnostic program from Dell's support pages showed that it had battery had 0% charge.
Consulting Google, I quickly gathered that this was a somewhat known problem on the Axim x3* series, and the only way to solve it was to replace the battery. I tried to find any detailed guides on the process, but exept for some scattered message board posts there was't much usefull info. I therefore decided to document what I did, in case somebody else runs across this exact same problem.
Dissection time:
Disclamer for morons: Follow this at your own risk. **** can happen, so don't screw around if you don't know what you are doing. If you are that kind of person that leaves electronic devices in more pieces than they originally came, just send it back to Dell and they'll fix it for you (it's probably cheaper than getting a new).
What you need:
  • Replacement battery: Varta V20HR
  • Small Philips screwdriver (I used size #00)
  • Strong tape or conducting glue to attach the wires to the battery (I used duct tape)
  • Small knife to open the plastic cover on the old battery
Step one is to open the device. First remove the main battery, any SD-card you might have in the slot and the stylus. Turn the device so the screen faces DOWN, and with something pointy (I used my nails) remove the rubber feet located in each corner. You should now see 4 screws as pictured to the right (bigger picture), so get a small screwdriver and unscrew those.
Next you got to separate the back plate from the rest of the unit. Just start in a corner and bend it outwards til it clicks out and continue this around the unit. It might be very stiff if it's the first time you remove it, so it can be smart to use a flat screwdriver to help with the bending. When it's all loose, just take it off.
You should now see something like the picture on the left (bigger version). Remove the three screws highlighted. Keep in mind that the topmost screw also holds the antenna in place (if you have the WiFi/Bluetooth version), so remove the screw, then push the antenna outwards to remove it (you need to do this on order to flip the mainboard later).
The three arrows at the bottom of the picture show the cables that needs to be unplugged to get access to the battery (Note: The arrows point the way you need to drag the cable to get it loose, not at the cable itself). The leftmost one (arrow pointing left) is to the speaker and is easy removable by pulling it towards yourself. The bottom (arrow pointing down) can be more tricky, there are two brownish hinges on each side of the white connector that needs to be pushed outwards. Once they are loose pulling the cable out should be easy. Third one (arrow pointing right) is the battery connector itself, just drag it the same way as the arrow and it should come loose.
Now from the left side of the motherboard simply pull bit to the left (to get the audio jack/selection wheel out of their grooves on the frame) and the fold the whole board over to the other side, giving you access to the underside. Here you should see the battery itself (in a green plastic cover, taped to the frame), and you can easily remove it.
Now take the knife and cut open the green battery cover. If you want to reuse it (and I suggest you do) be very carefull how you cut it open (I split it in the middle, and bent the old battery out). As you should be able to see now the actual battery is point welded to the contacts, so just removing the contact plates is out of the question. I suggest that you just separate the wires from the contacts (just pull them off) and then reattach them on your new battery. You are free to tackle this as you see fit (I used duct tape), but keep in mind that you SHOULD NOT use a soldering iron directly on any kind of battery, especially not as small as these (the heat will destroy them). Also be sure to get the polarity right, red wire goes to (+), black goes to (-).
When the wires are properly fitted put the new battery back in the green cover (or something else that insulates it from the mainboard) and reseat it where it used to sit on the frame. It can be smart to use some extra tape or glue to attach it if the glue on the frame itself is getting weak. Now simply reattach the cables and screw everything together, and your PDA should be as good as new. I slapped mine in the cradle right away, and after about 30 minutes the "low backup battery" warning disappeared, and the status changed to "normal" in the power settings. Matt Brown"Southall Technologies & Advertisement" 912 376-0472 web: "southalljrcta.com" Stimulas7@gmail.com
Was this helpful?
Yes
No
15 people thought this was helpful
Solution #7
posted on Oct 28, 2009
Not Rated)
ruckartj
Rank: Apprentice
Rating: 0%, 0 votes
Stimulas7's instructions above are right on the money! I found the battery at http://store.batteryspecialists.com/v20hr.html for only $3.99 FREE shipping, it arrived in just a few days, I followed the instructions above and my X30 is back in business!
Was this helpful?
Yes
No
Popular Solutions for Dell Axim X30 Pocket PC
Questions and Unsolved Problems for Dell Axim X30 Pocket PC
Do you recommend Dell Axim X30 Pocket PC?
Answer
Answer
I have vertical lines all over my screen.
Answer
The screen froze and now I can't even turn it on.
Answer
can the windows mobile new os setup for dell aximx30
Answer
how do i connect my dell axim x30 to my bt home hub so i can surf the internet? I am totally lost.... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 14, 2007
I need to replace the back up battery and don't know how to install it.
Thanks, Susan
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Axim X30 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 551
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
