Question about Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum
Hoover Wind tunnel V2
Hoover WindTunnel V2
When I turn on my vacuum the roller brush will not turn and I cannot find where a belt would go.  Please help.
  • 4 more comments
  • seladd Nov 08, 2007
    I also have the same problem. I have taken it apart as much as I can and can not seem to locate a belt. Please help.
  • Anonymous Nov 21, 2007
    The roller brush will not turn and the vacuum won't push forward. It's not picking anything up.
  • Anonymous Dec 27, 2007
    I have Hoover Windtunnel model U8143-900 and the brushes won't turn. I thought they were caught with hair, but have tried to clean it all out and the brushes still don't turn. The reset button keeps coming up and the light on the base comes on after a few seconds of being turned on. I took bottom cover off but couldn't get to much of the brushes, and i couldn't get them to turn manually. Any idea how to take it apart further? Thanks
  • Anonymous Jun 24, 2008
    I have the same problem. The hose works fun but the brushes won't turn and there is no suction under the vaccuum.
    Can a novice replace the brush rolls and/or the gear housing? Where can we bet instructions?
    Thanks!
  • Anonymous Apr 13, 2009
    Mine has suction underneath but one roller bar is frozen - the other moves when I turn it by hand. "Reset" button keeps coming on. This is an awesome vac when it works. Hoping someone can help!
  • Anonymous Mar 29, 2014
    Hoover central vac won't turn off when plugged into wall
    President:
  • 1,673 Answers
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. Hoover Wind tunnel V2 - ee84874.jpg
Posted on Jan 29, 2008
Mine was under warranty and they replaced the whole assembly for free. Apparently a quality and/or design problem.
Posted on Jun 17, 2008
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel 2 Making Noise While Operating
sounds like your brush roller bearings are going bador cloged up with carpet strands if you can take the bottom open and remove the brush roller look at the ends and see if you see any melted plastic or see if the ends feel loose like wobble back and forth.once you take the roller out turn the vacuum on and see if you hear the same noise.also check the belt and see if it looks burnt on the inside of the belt. and does it look stretched out .the belt might be stretched out and fluttering when running.feel free to cal me and maybe i can help you further with it.i'm not one of the techs .i'm just trying to help people.i don't charge for my advise
Apr 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
I got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Dec 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum Logo
1,071 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
