Question about Samsung SlimFit TX-S3082WH 30" TV
Blown fuse my fuse is blown on my 30 inch samsung where can i purchase one
  • 378 Answers
You can purchase it in any electronics shop, just tell them the rating Ex. 3Amp/240Vac you can see this rating at the cap of fuse.
Posted on Jun 02, 2009
Samsung plasma tv
Power supply may have failed.
Aug 15, 2016 | Samsung 51 INCH PS-51D450 PLASMA...
Where can i buy the ceramic fuse for my toshiba flat screen?
That model uses a e.t8ah250vp fuse and they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=316
The fuse is located inside on the power supply board.
Mar 27, 2013 | Toshiba 40E200U 40-Inch 1080p LCD HDTV
Samsung dryer not heating
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Mar 09, 2012 | Samsung Dryers
Samsung LE46M5 lost picture can not even get menue on screen still have sound. disconnected and reconected all wires cables and power no joy. is this expensive? purchased 06
t con board fuse may have blown very cheap to replace on the t con board there is a letter P on the board near to the cable end check this with a meter if blown replace with a nintendo fuse they are the same rating and cheap and easy to get hold off, or you can go to maplins and ask for a micro fuse 0.5amp fuse.
Feb 10, 2011 | Samsung LE46M51B 46 in. LCD Television
TV doesn't come on. Checked fuse in power board and is not blown. Samsung Tx 2675W thanks Eric eshackelford@kqed.org
I could be the capacitors problem on your power supply circuit. Just has it checked and replace the defective one
Jan 18, 2011 | Samsung SlimFit TX-S3082WH 30" TV
I have a Samsung Model PCN5425R Rear Projection TV. When I try to set the convergence, the red will not move whatever I do, but the blue works fine.
If it is rear projection set it uses either two of the STK-392-020 OR STK-392-040 CHIPS FOR CONVERGENCE OUTPUT.
BOTH WILL HAVE TO BE REPLACED; NOTE THAT THESE SETS ALSO HAVE "PICO" FUSES ON THE BOARD FOR EACH CHIP--no movement means one of the fuses is blown because the chip shorted.
This can be a do it yourself repair if you are handy; total parts cost if the parts purchased on Ebay is under 30 dollars.
Let me know if I can assist you and if you have any questions reply to the posting here.
REGARDS, SD TECH
Aug 10, 2010 | Samsung PCN5425R 54" Rear Projection...
After app. 30 seconds it shuts down and insists\r\...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung SlimFit  TX-S3082WH 30" TV Logo
180 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
