Question about HP DeskJet 5550 InkJet Printer
Can't re-lock printer back cover.
Is there a safe lubricant for the locking wheel/ cam assembly inside the standard 5550 printer back cover ?
    Novelist:
    Scholar:
  • 167 Answers
You can use less greasy oil or something like the vehicle engine oil.
Any kind of thin lubricant is always yield good results.
Do not use vegetable oil or cooking oil/sunflower oil etc.
Posted on Oct 27, 2007
  • Deepu Amalan
    Deepu Amalan Oct 27, 2007
    Actually a lubricant is not necessary.
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Apr 03, 2015 | 2003 Kia Sedona
Wheels keep coming off
1 - Remove rear wheel
2 - Remove posi screw from bottom of rear wheel hub assembly
3 - Allow bottom block and spring to fall into palm of hand
4 - Push rear wheel lock bottom down through rear assembly to remove.
5 - Clean wheel lock button and locking plate to ensure free movement.
6 - Clean rear hub and locking button housing with dry cloth.
7 - Apply lubricant thinly in recess to allow free movement of button (dry Teflon spray is best - find it in the laundry aisle of larger supermarkets)
8 - Re-fitting is reverse procedure of removal instructions.
Nov 30, 2011 | Quinny ZAPP Stroller
Where can i find a web page that can show me step by step Ignition Lock Cylinder Removal for gmc yukon 1996
When carrying a live inflator module, make sure that the bag and trim cover are pointed away from you. Never carry the inflator module by the wires or connector on the underside of the module. In case of accidental deployment, the bag will then deploy with minimal chance of injury.
When placing a live inflator module on a bench or other surface, always face the bag and trim cover up, away from the surface.
  1. Disconnect the negative battery cable and disable the SIR system.
  2. Remove the upper and lower shroud, air bag module and the steering column.
Exploded view of the removal of the SIR coil assembly
  1. Remove the retaining ring, SIR coil assembly, wave washer.
  2. Remove the shaft lock retaining ring using tool J 23653-SIR or its equivalent to push down the shaft lock shield assembly. Discard the ring.
  3. Remove the shaft lock shield and turn signal cancel cam assembly.
  4. Remove the park lock cable assembly from the lock module assembly.
  5. Remove the key alarm switch, if equipped by gently prying the alarm switch retaining clip with a small pry tool. Rotate the alarm switch 1/4 in. turn and remove.
  6. Remove the two tapping screws and the ignition key and alarm assembly. Let the switch hang freely.
CAUTION The lock assembly is under slight spring tension. Hold the lock bolt in place while removing the lock module assembly.
  1. Remove the three pan head tapping screws and the lock module assembly.
  2. Remove the backing plate from the module.
Mark the two sector gears at the OFF-LOCK position to ensure proper reassembly
  1. Remove the sector gears.
  2. Remove the positioning tab on the end of the lock cylinder using an 1/8 in. burring tool. Remove all burrs from the lock module and cylinder assembly.
  3. Push on the locking tab of the lock cylinder from inside the lock module assembly and remove the lock cylinder.
To install:
  1. Align the marks on the sector gears and install the gears and the backing plate to the lock module assembly.
  2. Install the lock cylinder set and ensure that the lock module assembly is in the OFF-LOCK position.
  3. Install the key in the lock cylinder and ensure that it is in the OFF-LOCK position.
  4. Line up the locking tab with the slots in the lock module assembly and push the cylinder into position.
  5. Rotate the lock cylinder to the ACC position. The alignment arrows on the sector gears should be pointing towards each other.
  6. Rotate the lock cylinder to the LOCK position. Push the lock bolt in until it is flush and align the lock module assembly with the head assembly and install the lock module assembly.
  7. Install the three pan head screws and tighten to 53 inch. lbs. (6 Nm).
  8. Install the ignition and key alarm switch assembly and the fasteners. Tighten the fasteners to 12 inch. lbs. (1 Nm).
  9. Install the key alarm switch. Make sure the retaining clip is parallel to the lock cylinder. Rotate the alarm switch 1/4 in. turn until locked in place.
  10. Lubricate the lower brass surface of the turn signal cancel cam assembly with synthetic grease and install the assembly.
  11. Align the inner block tooth of the lock plate to block tooth of race and upper shaft assembly and install the assembly.
  12. Install a new shaft lock ring using tool J 23653-SIR and ensure the ring is firmly seated in the groove on the shaft.
  13. Install the center race and upper shaft assembly.
  14. Place the ignition switch to the lock assembly and ensure the coil is centered.
  15. Install the wave washer and the SIR coil assembly.
  16. Install the retaining ring and route the coil wire along the steering column.
  17. Install the wire harness straps to the steering column harness.
  18. Install the park lock cable assembly with the transmission in Park and the ignition switch in the OFF-LOCK position.
  19. Install the upper and lower covers, lock cylinder set and tilt lever (if equipped).
  20. Install the steering column and enable the SIR system. Connect the negative battery cable.
Exploded view of the sector gear timing position (OFF-LOCK)
Jun 02, 2010 | 1996 GMC Yukon
How do you put in a ball joint in a 2001 sebring convertible
It depends on exactly which ball joint of the 3 per side your changing, but here are the details.
COMPRESSION LOWER ARM & LATERAL LOWER ARM ASSEMBLIES
Removal
1. Loosen compression lower arm ball joint nut. Using steering linkage puller, separate ball joint and
knuckle. Remove nut, bolts and compression lower arm assembly. Remove dust cover.
2. Remove stay. Remove shock absorber lower mounting bolt. Loosen lateral lower arm ball
joint and knuckle nut. Using steering linkage puller, separate ball joint and knuckle. Remove nut, bolt and
lateral lower arm assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for compression lower arm ball joint is 4-22 INCH lbs. (0.5-2.5
N.m) for 2000 models. On 2001 models, breakaway torque is 22-54 INCH lbs. (2.5-6.1 N.m). Ensure
breakaway torque for compression lateral lower arm ball joint is 13 INCH lbs. (1.5 N.m). Check compression
lower arm, lateral lower arm, dust covers, and bushings for damage and wear.
Installation
To install, reverse removal procedure. Use NEW ball joint nuts. Lubricate lip and inside of dust cover with
multipurpose lubricant. Using installer, install dust cover. Check front wheel alignment.
UPPER ARM ASSEMBLY
Removal
Using steering linkage puller, loosen upper arm ball joint and knuckle nut. Remove self-locking nut. Remove upper arm and upper arm shaft assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for upper arm ball joint is 3-13 INCH lbs. (0.3-1.5 N.m).
Replace upper arm assembly when measured value exceeds specification. Check upper arm, dust cover, and
Installation
1. To install, reverse removal procedure. Use NEW self-locking nuts. Lubricate lip and inside of dust cover
with multipurpose lubricant. Using Ball Joint Installer (MB990800), install dust cover.
2. Ensure upper arm shaft assembly is installed at indicated angle. Verify upper arm shaft
assembly installation. Check front wheel alignment.
Once you have the correct arm off and a replacement joint (if available, some are not serviceable and require the arm to be replaced) then you will need a press or a ball joint press to change the joint. Such as
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38335
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46389
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66958
or http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46967
Mar 17, 2010 | 2002 Chrysler Sebring
How to replace the ignition switch
  1. If equipped with an air bag, disable the system as outlined in of this repair guide.
  2. If not done already, disconnect the negative battery cable.
  3. Remove the steering wheel, as outlined earlier in this section.
  4. Remove the shaft lock cover.
  5. Remove the shaft lock retaining ring using a suitable lock plate compressor tool to press down the shaft lock. Dispose of the ring.
  6. Remove the shaft lock.
  7. Remove the turn signal canceling cam assembly.
  8. Remove the upper bearing spring.
  9. Remove the thrust washer.
  10. Move the turn signal lever up, into the "right turn" position.
  11. Remove the multi-function lever.
  12. Remove the turn signal switch arm retaining screw.
  13. Remove the turn signal switch screws and let the switch hang freely.
  14. Remove the key from the lock cylinder set.
  15. Remove the buzzer switch assembly.
  16. Reinsert the key in the lock cylinder.
  17. Turn the key to the LOCK position.
  18. Remove the lock retaining screw and remove the lock cylinder.
  19. If equipped with cruise control, remove the housing cover end cap, unplug the cruise control connector and gently pull through the shroud, bowl, and steering column housing assembly.
  20. Remove the washer head screw, the hex nut and dimmer switch.
  21. Remove the mounting stud and ignition switch.
    1. If equipped with cruise control, gently pull the connector through the steering column housing assembly, bowl and shroud and connect the plug.
    2. Install the housing cover end cap and screw and tighten to 17 inch lbs. (1.9 Nm).
    3. Install the ignition switch and mounting stud and tighten the stud to 35 inch lbs. (4.0 Nm). Adjust the ignition switch by moving the switch slider to the extreme left position and then move the slider 1 detent to the right (off lock).
    See Figure 1
    0900c152801dbcc2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Ignition switch adjustment procedure
    1. Install the dimmer switch hex nut, screw, and tighten to 35 inch lbs. (4.0 Nm). Adjust the dimmer switch.
    2. To adjust the dimmer switch, depress the switch slightly to allow insertion of a 3 / 32 in. drill bit into the hole above the actuator rod. Force the switch upward then tighten the screw.
    See Figure 2
    0900c152801dbcc3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Dimmer switch adjustment procedure
  22. Install the switch using the original screws. Use of screws that are too long could prevent the column from collapsing on impact.
  23. Install the lock cylinder and retaining screws and tighten to 40 inch lbs. (4.5 Nm).
  24. Turn the key to the RUN position.
  25. Install the buzzer switch assembly.
  26. Install the turn signal switch and retaining screws and tighten to 31 inch lbs. (3.5 Nm).
  27. Install the wire protector shield.
  28. Install the turn signal switch arm and retaining screw and tighten to 29 inch lbs. (2.3 Nm).
  29. Install the hazard knob assembly.
  30. Install the multi-function lever.
  31. Install the thrust washer and upper bearing spring.
  32. Lubricate with synthetic grease and install the turn signal canceling cam assembly.
  33. Install the shaft lock.
  34. Install a new shaft lock retaining ring. Align it to the block tooth on the shaft, using a lock plate compressor tool to press down the shaft lock.
  35. Install the shaft lock cover.
  36. Install the steering wheel, as outlined earlier in this section.
  37. Connect the negative battery cable. If equipped, enable the air bag system as outlined in of this repair guide.
Jan 19, 2010 | 1993 Oldsmobile Silhouette
Front brake rotor on 1992 Ford Ranger 4wd with auto lock in
With Automatic Locking Hubs
  1. Raise the vehicle and install safety stands.
  2. Remove the wheel lugnuts and the wheel and tire assembly.
  3. Remove the retainer washers from the lugnut studs. Remove the automatic locking hub assembly from the spindle.
  4. Remove the snap ring from the end of the spindle shaft.
  5. Remove the axle shaft spacer
  6. Being careful not to damage the plastic moving cam or thrust spacers, pull cam assembly off the wheel bearing adjusting nut and remove the two plastic thrust spacers from the adjusting nut. CAUTION: Do not pry on the plastic cam or thrust spacers during removal. Prying may damage the cam or spacers.
  7. Using a magnet, remove the locking key. NOTE: If required, rotate the adjusting nut slightly to relieve pressure against the locking key, before the key can be removed. CAUTION: To prevent damage to the spindle threads, look into the spindle keyway under the adjusting nut and remove the separate locking key before removing the adjusting nut.
  8. Loosen the wheel bearing adjusting nut from the spindle using a 2-3/8 inch Hex Locknut Wrench T70T-4252-B or equivalent.
  9. While rotating the hub and rotor assembly, tighten the wheel bearing adjusting nut to 47 Nm (35 ft lb) to seat the bearings. Spin the rotor and back off the nut one-quarter turn (90 degrees).
  10. Retighten the adjusting nut to 1.8 Nm (16 in lb) using a torque wrench.
  11. Align the closest lug in the wheel bearing adjusting nut with the center of the spindle keyway slot. Advance the nut to the next lug if required. Install the separate locking key in the spindle keyway under the adjusting nut. WARNING: Extreme care must be taken when aligning the spindle nut adjustment lug with the center of the spindle keyway slot to prevent damage to the separate locking key. The wheel and tire assembly may come off while the vehicle is in motion if the key is damaged.
  12. Install the two thrust spacers and push or press the cam assembly onto the locknut by lining up the key in the fixed cam with the spindle keyway. CAUTION: Extreme care must be taken when aligning the fixed cam key with the spindle keyway to prevent damage to the fixed cam.
  13. Install the axle shaft spacer.
  14. Clip the snap ring onto the end of the spindle shaft.
  15. Install the automatic locking hub assembly over the spindle by lining up the three hub assembly legs with three pockets in cam assembly. Install the retainer washers.
  16. Install the wheel and tire assembly. Install and tighten lugnuts to 135 Nm (100 ft lb).
  17. Make sure the final end play of the wheel on the spindle is 0.00-0.08 mm (0.000-0.003 inch). the maximum torque to rotate the hub is 2.8 Nm (25 in lb).
Jul 27, 2009 | 1992 Ford Ranger
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Ignition stuck in lock position
First, lubricate the key cylinder by spraying wd-40 into it -- this usually frees it.
You can also move the steering wheel back and forth while wiggling the key -- sometimes the steering wheel lock binds the key cylinder.
If this works, you can follow up the wd-40 lubrication with graphite lock lubricant (Pep Boys).
If lubrication doesn't work, let me know, we'll go to the next step.
Apr 23, 2009 | 1992 Toyota Pickup
Rear wheel bearing
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
  1. Remove the differential pinion shaft (4211).
    1. Remove the differential pinion shaft lock bolt (4241).
    1. Remove the differential pinion shaft.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
    Remove the U-washer (4N237).
    1. Push the axle shafts (4234) inboard.
    1. Remove the U-washer.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
    Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
    Remove the axle shaft.
Rear Wheel Bearing and Axle Shaft Oil Seal Removal
  1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
  1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
Installation
  1. Lubricate the new rear wheel bearing with the specified lubricant.
  1. Using the special tools, install the new rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. Using the special tools, install the new wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Installation
  1. Lubricate the lip of the wheel bearing oil seal
    Install the two axle shafts.
    Install the U-washer.
    1. Position the two U-washers on the button end of the axle shaft.
    1. Pull the axle shaft outward.
  1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
    Install the differential pinion shaft.
    1. Align the hole in the differential pinion shaft with the case lock bolt hole.
    1. Install a new differential pinion shaft lock bolt.
  1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
  1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. Install the rear brakes. For additional information, refer to Section 206-04 .
  1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Lower the vehicle.
Apr 10, 2009 | 2004 Ford GT
Changing steering wheel lock has engaged
The steering wheel lock is a metal prong that protrudes into the steering shaft from within the ignition lock assembly, that is held on by two security screws pointing upward underneath the plastic steering column covers. You can remove the 2 screws and check out the working of the mechanism. It's probably stuck. Most likely, when you put on the new steering wheel, you simply twisted the ignition assembly and it is now causing the steering lock to be wedged on in the lock channel. Try twisting it back the other direction with your hands and I'm pretty sure it will allow the spring loaded locking mechanism to release. This same problem happened to me and took me a while to troubleshoot what was going on in the mechanism and figure it out. If twisting it both directions and checking to see if it releases with the key turned doesn't fix it, just remove the ignition assembly and lubricate the locking mechanism bolt and that will fix it for sure.
Apr 09, 2009 | 1989 Ford Festiva
HP DeskJet 5550 InkJet Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
