Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Digital Tv is stuck on a channel
Can anybody help.
My samsung le32r7 lcd tv digital tv is not working properly, The DTV is stuck on one channel. The on screen text display does not go away. None of the functions of the DTV work either, D.menu does not work, i am unable to review the tv guide.
any help would be much appreciated.
  • 12 more comments
  • Anonymous Dec 09, 2007
    i have exactly the same problem! although my tv is a model up from johxh's, can any1 help?
  • Embo36 Dec 10, 2007
    I have exactly the same problem
  • Anonymous Dec 25, 2007
    the same fault as johxh"s tv
    digital channel stuck and can`t excess digital menu
    i was told it was an ariel fault but had new ariel fitted
  • Bretlach Jan 25, 2008
    I already posted elsewhere, but then saw this problem, exactly the same as mine, its just stuck on film 4.
    problem is the service menu doesnt come up using those button combos, have Samsung changed them?
    my exact model is LE32S73BDX any suggestions?
  • Sporty10 Feb 05, 2008
    Hi, Have the same problem with a Samsung LE26R73BD, channel frozen, cannot change. Codes do not appear to work for this model, does anybody have any other suggestions. Help
  • Gf26 Apr 26, 2008
    I have a Sony Trinitron KV32XBR100 the not responding to channel controls on remote and I don't know how to + or - channels. Something I
    do with the remote is making the channel stay on one station.
  • Anonymous Dec 27, 2008
    Solution above worked brilliantly - no mention of the hidden menu in the handbook so would have paid an engineer a furtune to do what i've just done in 5 minutes. Thanks all!!
  • Anonymous Jan 07, 2009
    I have the same problem, my TV is stuck on one channel... but the hidden menu won't appear after pressing: info, menu, mute, power... HELP????
  • sandys885 Feb 16, 2009
    LG 60PG60 plasma tv is stuck on one channel. Have turned tv on and off and tried changing channels with the remote and will not change. Does anyone know what is wrong with it??
  • johnjorda224 Apr 24, 2009
    Thanks for this info guys. When I follow these steps it brings up the secret menu and I scroll down to line 12 but nothing happens when I press the OK button. Any ideas. Thanks again.
  • Anonymous May 24, 2009
    It is a samsung - and i tried the secret menu, got to the reset option (12) however how do i accept the change? If i press ok nothing happens. My Tv is stuck in mono mode also
  • colinmac May 11, 2010
    Tried the hidden menu thing and it worked first time!!
    Thanks all for help
  • Jim Nye Dec 21, 2012
    Yes! - it took a couple of tries but it worked. I wonder why this problem occurs. I also wonder who designed a system that requires what amounts to a hack in order to tune your TV. And while I'm at it, the manual for this TV is shockingly poor..
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
  • 1 more comment
  • shroom42 Dec 30, 2007
    I just found the solution to this problem.
    Press these buttons on the remote while the tv is in standby
    Info, Menu, Mute, Power On.
    You will then see a new menu and on line 12 there is a reset option.
    Worked a treat for me, goodluck :)
  • stewthenoo
    stewthenoo Nov 17, 2012
    BINGO, Indeed. Worked first time and ended a very frustrating afternoon. VMT
  • davidatkin2
    davidatkin2 Jan 07, 2013
    This hasnt helped. Text box stuck, channel stuck. Tried 5 times. Any ideas?
This method finally worked after a few times so don't give up. Also you should try scrolling left and right on reset line 12 of secret menu and play about a bit. Brilliant guys...CHEERS. :)
Posted on Apr 24, 2009
  • 1 more comment
    Hi. Got the secret menu up for 6th or 7th time and I scrolled left and it went off,,,,when i pressed Power On button it came to 'Plug & Play' menu and I installed the channels as if I had just bought the TV and it started to load all the DTV channels. Now working fully. I suggest keep trying this method and even unplug the set overnight then try again and again the next day. It eventually worked for me. Many thanks to all involved.
  • davidatkin2
    Tried this five times, its not helping. On screen text is stuck, with time at 10:01am, it is now 8:43pm, and it is stuck on BBC1. Help!
  • Chan May 04, 2013
    I can get the secret menu up but can not then scroll up or down to select anything?
I had the same problem as of last night - very odd! Picture stuck with little access to functions. Solution worked on 2nd attempt - thank you - you saved us a small fortune probably as guarantee ran out last month!
Posted on Jan 11, 2008
Best solution worked a treat! Thanks.
Posted on Jan 24, 2008
Thanks guys!
Posted on Mar 30, 2008
Thanks for the info.Had to auto reset but it worked a treat
Posted on Jan 12, 2008
I have had the same problem found hidden menu went to line 12 reset pressed said wait then screen went black and nothing happened! Can anyone help
Posted on Dec 21, 2009
My remotes broke so how can i reset my samsung
Posted on Nov 01, 2008
Thankyou that was a very helpful tip.it worked 100%
Posted on Feb 01, 2008
I also have the same problem
Posted on Dec 21, 2007
Did you manage to solve this as i have the same problem
Posted on Dec 15, 2007
    New Friend:
Don't work my tv is literally stuck my tv remote doesn't work I have replaced batteries the only thing I could do is click menu on the side of the tv
Posted on May 23, 2013
  • John Mantova Dec 23, 2015
    leave TV 0n and unplug from the mains socket. Wait two mins and ease the plug back in until standy light flicks on Pull it back and push in again .do this twice then push home completely the Tv may come back on or go into stand by mode If into standby click on as usual. You may have to do this a couple of times
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Do you need a cable box for it
U mean a digital converter box for getting free broadcasting DTV airing channels?No,this tv it is a digital tv,just require a roof or a good digital antena.Hook it up with the antena and goto tv menu go to setup go down to Ch.pick AIR not CABLE and go into scanning for DTV channels after that tv will get all the free broadcasting DTV air channels.
Feb 17, 2011 | Toshiba 19HLV87 19 in. LCD HDTV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung LE32R7 Picture come on then goes straigt off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 26, 2017 | Samsung LE32R72B 32 in. HD-Ready LCD...
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Not picking up digital channels on my Dynex TV
My Dynex tv isn't picking up my digital cabel any suggestions for me Please!!! I am lost without my TV!!!!
Aug 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Dec 31, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Dec 15, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
7,637 people viewed this question
Jerry Greenberg
Jerry Greenberg
