Question about KitchenAid KTRS22EM Top Freezer Refrigerator
Freezer is not cold and ice is building up on the bottom back
The freezer is not cold but it is running. there is ice build up on the bottom back of the freezer. help!
  • 3,267 Answers
Since this model is frost free and u are finding ice in the bottom back the problem may be due to either or both of these:
  • Low refrigerant coolant gas(freon/CF4)
  • The fan & heater *** blower assembly could have malfunctioned. To check put ur hand near the outlet of the bower outlet to feel if the fan is operational.
This may be the first things to check and post ur reply as comment for us to help find the exact problem..........................sodeep
Posted on Jun 02, 2009
My samsung rs20br has ice build up on the floor of the freezer, under the bottom drawer. I defrosted it but it has come back . How can i fix this?
Believe it or not your freezer has a heater that defrost your freezer. It runs on a cycle to keep the ice from building up. Your freezer may be set to cold or the heater isn't working properly.
Jan 18, 2018 | Samsung Refrigerators
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
IceBoxnot getting cold
sounds like a similar problem I have, but with a top loaded freezer/refrigerator. I took the back panel of the freezer out (carefully so as not to break anything). I discovered ice covering everything; coil, defrost heater, and perhaps a defrost timer (I didn't see one). I suspect (according to what I've been able to find on the internet without having to pay for a response) that the defrost heating element and/or defrost timer are defective. I only use this 4 yr old refrigerator seasonally, so I don't mind having to manually defrost the freezer. I will try to get parts in the states when I return in the fall. This doesn't tell you how to repair the problem in entirety; but it may give you a hint and possible temporary solution. Oh, I used a hair dryer to melt all the ice covering the above noted freezer parts. My refrigerator is working just fine; however, I'm sure that it'll build up with ice once again. I'm leaving in 6 weeks, so I don't care so long as I know that I can remedy the problem for now. The article I read recommended using a volt meter tester; that I'm not familiar, it may very well allow me to determine which part is defective. The heater coil is about $25, I didn't check on the timer. Try this site: http://www.applianceaid.com/defrost_cycle.html . Good luck. Tom
Jul 26, 2008 | Amana ABB1927DE Bottom Freezer...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
KitchenAid KTRS22EM Top Freezer Refrigerator Logo
163 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
