SOURCE: 1999 Chrysler Concorde LXI 3.2
This sounds as if the input and output speed sensors may be having an issue. If you are putting a used tcm in it will have been powered down and basically reset to it's defaults.Would completely disconnect the battery and hold the cable ends together this will force a hard reset of the tcm and ecm which will return all adaptives to the factory presets.When started it may run very poorly for a few minutes until it relearns. You then should be able to drive it and it will continue it's adaptive learning curve.
SOURCE: 2001 01 Chrysler PT Cruiser TCM Transmission Control Module how to reset
2001 ptc wont go into any gears
