Question about RCA HD52W59 HDTV Projection Television
Menu screen appears constantly, volume decreases by itself
Menu screen keeps appearing and alternates with the volume.When i press the clear button it goes away but only for a secondand then its back, and sometimes the volume decreases all by itself.I thought it might be the controler but it happens w/out batteries.
    Scholar:
  • 150 Answers
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Posted on Jun 02, 2009
How to Reset the Velocity Cruz Tablet?
A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The Cruz logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A.
NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.)
In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
Oct 17, 2016 | Android Tablets & eReaders
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
Sep 06, 2015 | CELLULARVILLA Wallet Case For ZTE Speed...
I CANT REMEMBER MY PATTERN LOCK ON MY MICRO CRUZ VELOCITY READER I HAVE PUT IN WRONG PATTERN 40 TIMES N ITS STILL NOTHING.. HELP ME SOMEBODY PLEASE N THANK U
Hi, you will have to factory reset! Follow these instructions:
C.) In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
Jan 25, 2015 | Velocity Tablets & eReaders
Forgot password unlock phone
You can remove the lock screen but your storage will be totally erased. This feature is enabled only for security purpose.
Step 1
Flip your HTC Evo over, and pull the rear cover off of the device. Lift the battery out of its recess, and wait for about five seconds. Return the battery to the HTC Evo, and replace the battery cover.
Step 2
Hold down the "Volume Down" button on the Evo's left edge. Press and release the "Power" button. Instead of the standard power-up and lock screen, a new menu will appear on the LCD.
Step 3
Release the "Volume Down" button after the menu appears on the screen, then tap the "Volume Down" button twice to highlight the "Clear Storage" option.
Step 4
Press the "Power" button to choose "Clear Storage." Press the "Volume Up" button to confirm that you want to erase everything on the Evo. After a few moments, the Evo will reset itself and the screen lock will be gone.
Nov 12, 2013 | HTC EVO 4G Sprint - /
Dx-ldvd22-10a does not power up what part do you think broke
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you saveicon1.png any picture settings such as brightness or contrast.
To get the TVicon1.png out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with "Dynamic Mode" shown on the screen. At this point the picture parameters can be changed and saved.
If this method doesn't work for your TV there is an alternate method that might.
From the buttons on the front of the TV (not the remote):
1) Press the Volume + (increase volume) button
2) Whilst the volume button is pressed, press and keep pressed the menu button
3) Let go of the volume button and keep the menu button pressed for 5 seconds
4) After this time the screen should go blank and "Dynamic" will appear at the bottom of the screen.
from
http://www.fixya.com/support/t399140-samsung_le46f8_picture_setting
Jul 27, 2013 | Televison & Video
Forgot my password to my cruz
Factory reset-
A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The CRUZ logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A. NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.)
Feb 24, 2013 | Tablets & eReaders
Trackfish 6600 stops and starts again by himself many times in a few minutes; first screen map thouthand miles away from real boat position !
Try a factory reset - that worked for me when my Northstar Explorer 660 stopped by itself again and again. You find this reset commando by pressing MENU twice and then under Systems menu, if I remember it correctly. There is also a RAM Clear commando. This is done by holding the MENU button pressed when the GPS is switched off. Keep it pressed while switchin on the GPS, still holding the button pressed until the RAM Clear menu appears. You will probably loose all waypoints etc. by doing this so try Factory Reset as your first alternative. Good Luck! // Jonas, Sweden
May 12, 2011 | Northstar Explorer 660...
Main menu locked om dell w2306c
Use the side panel buttons to unlock the TV Menu and side panel buttons:
  1. Press the Menu button.
A message appears stating that the TV Menu and buttons are locked.
2.While the message is on the screen, press the volume decrease and channel up buttons on the side panel simultaneously. A message appears stating that the TV Menu and buttons are unlocked.
GOOD LUCK AND PLEASE RATE THIS POST!!!
May 09, 2011 | Televison & Video
I have galaxy tablet and need to delete all personal information from it.
Hey there,
1. Turn off device
2. press and hold Volume Up and Power
3. Release the Power button when you see the Samsung logo, but continue to hold
Volume Up until the recovery screen appears.
4. Use the Volume buttons to navigate the menu and select wipe data / factory reset.
5. Press Home to choose the selection.
6. Press Volume Up continue
The galaxy tab should not hard reset itself.
Hope this helps.
Mar 16, 2011 | Computers & Internet
RCA HD52W59 HDTV Projection Television Logo
147 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
