Question about Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
WEP security setup on SBG900
How do I set up WEP security on SBG900 - followed online setup then lost my connection. Not an expert but want to figure this out.
  • 244 Answers
If you set a WEP security connection, of course you will be kicked out of your connection. You have to re configure your laptop to gain access to your WiFi, inserting the new password you set the WEP with... Hope this helps
Posted on Jun 14, 2009
  • lawrence88 Feb 05, 2011
    The problem with the sgb900 is that the instructions tell you to set to wep or aes before you can insert the wep key. Yes really, it does not allow insertion of the wep key prior to activation of the wep or aes, hence it locks you out and there is no way to determine what the key ought to be.
    Clearly designed by a programmer, sigh!
    It may be that there is a config tool as that is mentioned in the manual, and or the settings will activate if you use I.E (I am in this instance workign from a mac using firefox and the settings are not becoming active before locking me out).
How do I secure my connection?
Hi. There's a lot of ways to secure your connection. Just follow this link
http://media2.comcast.net/anon.comcastonline2/support/help/manuals/Motorola_SBG900.pdf
May 14, 2011 | Arris SURFboard SBG900 Wireless Router...
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
Where do i find the wep? i am tryin to connect my ps3 to the wifi.
HI,
Please go to one of the computer which can go online
browser (for example, Microsoft Internet Explorer or Netscape
Navigator®).
now you would be able see your WEP key
Hope it can resolve your issue
Thanks for using Fixya
Apr 19, 2010 | Arris SURFboard SBG900 Wireless Router...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
How do i secure it
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 10, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900 settings set back to default settings
This exact problem just happened to me today. I called Motorola & they said this sometimes happens as a result of a power surge (can be on the cable or power lines). All settings were lost & I had to redo the entire set-up from scratch.
Jun 29, 2009 | Arris SURFboard SBG900 (49402201900) Modem
I cant find my wep key for my motorola sbg900 and i need it to get online for my ps3. how do i find it?
Usually to do this, you need to connect to the router with a computer and an ethernet cable.
Start the browser and enter the following:
http://192.168.100.1 or http://192.168.0.1
This should bring you to a configuration screen of the router. Next, go to the configuration tab and head out for the wireless configuration and then the security configuration. In there you should find the location where the WEP keys are stored.
if you can't get connected, yu can look for more help in the manual of the device.
You can download it here:
sbg900 manual
Cheers
Critter
Jan 04, 2009 | Arris SURFboard SBG900 Wireless Router...
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
Password for setup program lost /WEP-key??
If by set-up program you mean 192.168.0.1, then the default password is "motorola" and username is "admin" from there you should be able to see everything you need. If you changed it from the defaults, then you might have to reset the SBG900 to factory defaults by pushing and holding the small reset button on the SBG900.
I never had to run any "setup program" to get mine working, just plug and play. If you did need to install additional software then you might have problems that I am unaware of. Hope I was able to help.
Nov 15, 2008 | Arris SURFboard SBG900 Wireless Router...
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point Logo
1,519 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
