Question about Samsung WF337AA Front Load Washer
Help remove and replace the diaphragm on my samsung J845
I need to replace the door diaphragm on my samsung J845, can anyone help on how to remove the old damaged one and replace it with a new one?
  • 30 Answers
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Posted on Jun 02, 2009
  • Rdavis830 Jun 02, 2009
We have a Samsung J845 Front Loader. The door lock shorted out so we replaced it with a new one but now are just getting a DE error.
DE is door lock error possible main pba or wire harness check connections on new switch first .ohm wire harness If you can to check for break in wire
Mar 12, 2016 | Samsung Washing Machines
I am trying to replace my samsung J845 door interlock switch but have lost my wiring diagram. Can anyone tell me what colour wire to what pin?
I found this pic on Google images. Hope this helps. I was having the same problem as the whole door lock and the wiring connectors were all melted because of a short. Samsung washer door interlock mechanism and wiring connections.
Jul 19, 2012 | Cars & Trucks
How do I remove and replace the door seal on a wf317aag washer DC64-00802A - Door Diaphragm / Sealing Rubber
you can go to applinancerepairplanet.vstore.ca for a sevice manual on this to help you in this mater.
Dec 15, 2010 | Samsung WF337AA Front Load Washer
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Our samsung j845 front load washing machine won't
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
Door to my sumsung j845 will not unlock
i have the same problem and i rang samsung and they told me how to reprogram the machine. They told me to turn it off at the power point for 45 minutes, then plug it back in and turn the power on (not the machine)  and leave it for 15 minutes, then turn the machine on and hopefully it will unlock within 5 minutes. I had no luck with this so am getting someone out today.. hope you have better luck!
Jul 14, 2009 | Samsung WF203ANW Front Load Washer
Broken door handle on a samsung j845 washing machine. i need a replacement.
http://www.pcappliancerepair.com/
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
try these two places to order the handle. You will need the complete model number ,
from the sticker in the washer door jam
Please remember to give me a good rating
Dec 05, 2008 | Samsung Washing Machines
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
Samsung WF337AA Front Load Washer Logo
917 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
