Question about Dometic Rooftop RV Air Conditioner
Dometic AC that the fan shuts off but the compressor keeps running
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i could be wrong about this one) how can i fix this problem so i dont have to run my emergency heat all the time Fan goes off but compressor stays on when coach reaches temperature set on thermostat
    President:
  • 3,433 Answers
Call dometic dealer. I hear they have a bad circuit board that is replaced.
Posted on Jun 02, 2009
  • Ned C Cook
    Ned C Cook Jun 02, 2009
    call dometic dealer. I hear they have a bad circuit board that is replaced.
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Dometic penguin air ac
either the fan motor or heat strip
Apr 02, 2014 | Dometic Rooftop RV Air Conditioner
AC fan runs when heater is turned on in RV Dometic single zone
the heat and cool use the same fan. if compressor is running with heat then you have relay issue
Jul 05, 2013 | Dometic 3313192.000 White Single Zone LCD...
Dometic roof ac will not cycle
check wiring and dip switches make sure fan on auto
Jun 14, 2012 | Dometic Rooftop RV Air Conditioner
My ac turns on but just humms, no fan no cold air. a lil gurgling. it worked in my driveway,but when i arrived i can't get it to turn on.
your compressor is starting but the fan(s) are not running,leading to the shut-down of the unit, especially if the condenser fan doe's not operate for heat transfer off the condenser coil to remove the "latent" heat generated by the compressor so it is short cycling and will not keep running to cool this area
Jun 06, 2010 | Dometic Rooftop RV Air Conditioner
RV Air conditioning not working properly
IF YOU HAVE A ENERGY SAVER SETTING ON TSTAT SET TO OFF THAT WILL KEEP FAN ON WHEN COMPRESSOR IS OFF. REMOVE LITTLE THERMOSTAT WIRE IN FRONT OF COIL WHERE FILTER IS , BE CARFUL NOT TO BEND IT IN HALF IT CONTAINS GAS IN IT MOVE IT SLOW ,ITS ABOUT COAT HANGER THIN OR HAS A BULB AT END . CARFULLY STICK IN WARM WATER GLASS TO SIMULATE HOT TEMP. SEE IF IT STAYS ON. NOTE BULB HAS NO WIRES ON PROBE. MOST ARE ALLUM. OR COPPER. IF YOU ARE NOT SURE WHAT YOU ARE STICKING IN WATER THAN HOLD BULB IN YOUR FIST CLOSED TO HEAT UP BULB IT WILL WORK THE SAME.
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
FAN SHUTS OFF BUT COMPRESSOR KEEPS RUNNING - 6 MONTHS OLD
Depending upon the model of your air conditioner, this may be normal operation.
My newer Dometic air conditioner will run the compressor in a "reverse" mode without the fan occasionally in order to heat the coils. This is done to defrost the coils. After the frost is gone, the fan switches back on and everything goes back to normal.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
587 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
