Question about HP Pavilion dv9700t Notebook PC
Black screen I have an HP Pavilion dv9700t notebook bought last July. Recently the screen started staying black any time I closed the lid and opened it. After a couple days of this constantly happening the screen started to occasionally break up into four sections when it wasn't black. It still works fine in safe mode. Usually the only way to get the screen to not be black is leave the computer shut during startup until the login screen appears, but after logging in it does the break up thing.
  • sublimer1990 Jun 02, 2009
    Are you sure it's the resolution? Changing it doesn't really seem to help at all. As for the screensaver or sleep mode being on, usually it shows the mouse or the background for a moment before going to the black screen.
  • HP Master
  • 5,660 Answers
If the screen is breaking up into multiple screens, the video resolution isn't set correctly. Change the video properties back to the native resolution.
Right-click on an empty area of your desktop screen. Click on Properties at the bottom. Now click on the Settings tab.
The Screen Resolution slider should be all the way to the right, close to -> More.
The Colors should be set to the highest setting.
When you close the lid, you may have your laptop set to Sleep Mode, check that. You may also have your screen saver set to Blank, and no screen saver has been chosen.
(1.Screen Saver: Right-click on empty area of desktop>Properties>Screen Saver.
2.Sleep Mode: Start>Control Panel>Performance and Maintenance>Power Options>Power Buttons>When I press the sleep button on my computer>Then choose what you want it to do)
If none of this helps, I suggest you have a problem that HP needs to repair. Since you bought this dv9700t last July, would I be correct in assuming it's still under warranty?
Posted on Jun 02, 2009
  • joecoolvette
    joecoolvette Jun 03, 2009
    Suggest you contact HP, and get the Restoration Disk for YOUR laptop. Then do a Repair. Last time I sent for one, (Approximately a year and a half ago), the disk was free, the shipping and handling was not.
    $17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
    This is HP.com/Support,
    http://welcome.hp.com/country/us/en/supp...
    On this page under the first block, (Middle column), you will see ->
    How do I find my product name/number? <- in blue.
    Click on this, and then click on -> Pavilion laptops
    You need the product name and number, to give to Technical Support. I also would recommend writing down the Serial Number. (S/N:) (You'll find this on a white Service Tag, on the bottom of your laptop)
    Now go back to the main Support page you came from, and click on -> Contact HP, in the upper left corner.
    On this page under the orange -> Call HP <- heading, click on
    -> Technical support after you buy.
    You want the toll free number -> 1-800-474-6836
    Tell them that you need the Restoration Disk for your laptop. Have your written information handy.
    After you install the disk, follow the instructions. When you come to
    Repair or Fresh Install, do a Repair.
Pavilion dv9700, screen goes black if Iclose it. Take it apart, put it back together and works fine. Close top. goes black again. Take screen apart screen ok. What the heck. Inverter connections look ok....
Sounds like a loose lcd cable, I'd check to make sure it is secure (back of lcd) and where it connects to the motherboard. Usually a piece of tape right where it connects solves the problem ;)
Oct 09, 2010 | HP Pavilion dv9700t Notebook PC
Cant open my laptop hp pavilion dv9700 its not opening
find it on utube
U need to start by removing top panel above ur keyboard
Feb 07, 2010 | HP Pavilion dv9700t Notebook PC
My hp pavilion dv9700 screen stays blank when opening it up. The led lights are on and the computer is running but the screen does not come back on. If I wiggle the screen at the left hinge when the screen...
most likely you have a loose connection between your motherboard and lcd screen or the video card is dying you can test it by puting another monitor on your laptop if it works fine then it the connection. if the problem still exist its the video card
Jan 06, 2010 | HP Pavilion dv9700t Notebook PC
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
Comp fail
Try to boot the computer with your windows installation disc. If it will boot off the disc, try to perform a start up repair. When you write back, give as much information as you can about the computer
Sep 06, 2009 | HP Pavilion dv9700t Notebook PC
HP Pavilion dv9700 black after closing lid.
when you changed it to do nothing on battery or power did you save these settings........I know it is a silly question but it sounds like the laptop is going into Hibernate mode
Jul 31, 2009 | HP Pavilion dv9700t Notebook PC
Screen stays black
There is few reason. Either your one of RAM is defective. Try both memory one by one. Even though if U don't see screen than its time to change motherboard.
Jul 21, 2009 | HP Pavilion dv9700t Notebook PC
DV9000 Black Screen
You just need to diable presentation mode.It's not the switch.
Mar 22, 2009 | HP Pavilion dv9000t PC Notebook
Locks screen when I close the lid on my hp pavilion dv9740us
computer has gone into hibernation. Best to shut that function off, and replace with standby.
If you want it to hibernate, press the power button once, and it should come back on to the log in screen.
Mar 14, 2009 | HP Pavilion DV9740US Laptop
Lcd is black on start up only after closing lid. HP dv9000
first do a hard reset that disconnect the ac adoptor and the battery form the notebook and press the power button for 30 second and then only connect the adoptor and power on the notebook as the notebook boot up get connect to the internet to the hp.com site and do a bios update on the notebook
Mar 12, 2009 | HP Pavilion dv9005us Notebook
Open Questions:
HP Pavilion dv9700t Notebook PC Logo
361 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
