Question about LG VX5200 Cellular Phone
Phone problem My phone when turned on says use genuine battery then shuts down after 10 seconds. I have'nt have any problems before. I have a LG VX5200 phone can you tell me whats wrong? Thank you.
Re: Phone problem
Same thing happened to my brothers phone. Its software i believe you will have to go to the verizon store to fix it. He ended just getting a new phone
Posted on Oct 25, 2007
0 characters
3 Points
On power up, why does it indicate 'use genuine battery', then shuts off?
If your phone does not indicate it is charging, the 'use genuine battery' message may its way of telling you the battery is defective.
Nov 23, 2015 | LG VX8350 Cellular Phone
Fix error "use genuine battery"
Battery is bad and producing a very low voltage. Phone thinks you have the wrong battery.............. or you really do.
Oct 31, 2013 | LG Cell Phones
My Verizon LG EnV3 is saying Use genuine battery and then powers down in 10 seconds. I've tried most of the suggestions people have posted and they haven't worked. Please help! I don't kno
I had 3 Verizon LG VX 5500 and 1 told me the same thing. I just ask a friend for an old phone and then I activate it on the verizon website and no problem... it can't be fixed once is asking you for a GENUINE BATTERY, you need to get another phone. Also you can get the same phone in ebay (used) and activated it yourself.
Mar 25, 2013 | LG enV VX9900 Cellular Phone
My lg vx9900 shuts down at random times. when i turn it back on it says "use genuine batter" then does a count down from 10 and shuts back off
Take the battery out and wiped it off with a clean, dry cloth and try again.If is still doesnt work buy a new battery
Jan 10, 2010 | LG enV VX9900 Cellular Phone
Phone wont turn on
Your phone is detecting a not genuine battery.You should use a genuine battery for your phone to avoid this kind of warning.
Dec 15, 2009 | LG VOYAGER VX10000 Cellular Phone
LG 9400 cell phone
take it back to verizon. unless your using a 2nd hand battery
Aug 31, 2008 | LG VX9400 Cellular Phone
"use genuine battery" message
Because you are using a battery with more mAH your phone is not getting it. Have you got the same from LG, if so ask them for compatible battery. If not don't try such things. Better you get two batteries of lower mAH.
Feb 09, 2008 | LG VX9800 Cellular Phone
LG VX5200 Battery issue
Sounds like a mfg. defect. I have never had a phone on Verizon system do that, or an LG but I would be curious to see if it kept on occurring once you get a generic battery from a reputable online site.
Oct 14, 2007 | LG VX5200 Cellular Phone
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
LG VX5200 Cellular Phone Logo
70 people viewed this question
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
