Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Dont turn on
I have a samsung hdtv model # HCN4226W and when i try to turn it on it sounds like it turns on and then a red light flashes. Im not certain if it is a module problem or a power generator or something else? Please help!
  • marlaann1026 Jun 02, 2009
    I WOULD LIKE TO FIX THIS PROBLEM MYSELF BEFORE HAVING TO TAKE IT TO A SHOP.. DO YOU KNOW HOW I CAN DIAGNOSE THIS PROBLEM?
  • 378 Answers
Sometimes a small signal diode in power supply side is shorted. or IC component damaged.
Posted on Jun 02, 2009
  • Darial Jr Lasaria
    Darial Jr Lasaria Jun 02, 2009
    if you have a multimeter, turn off the power first before you open the back cover. then check the diodes near the SMPS section.
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Dec 11, 2009 | Samsung HCN4226W 42" Rear Projection...
Tv wont work
A VERY COMUN PROBLEM WITH THIS TV IS THE CONVERGENCE IC STK392-040 AND 2 RESISTOR 2.2 OHM
Apr 21, 2009 | Samsung HCN4226W 42" Rear Projection...
Tv fails to power on red light glows around power button on tv
there is somthing like puse in the back in side it cost u near about 200 $ put that it gone work 101percent
Dec 12, 2008 | Samsung HCN4226W 42" Rear Projection...
No power
you can get a replacement deflection board at the following link. If you dont know which one your model requires leave them a email with your model number and what youre needing they respond quickly and will provide the proper one for your model.
http://servicemanuals.vstore.ca/
Aug 27, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung series 550 1080 hdtv power problem
Is the TV main switch turned on?
There might be a main power switch on the TV somewhere.
Jul 16, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung tv
as far as it turning off on its own I would get a fan on it and see if that make a difference make sure that the fan is able to flow around the tv especially through the back of it, if this stops it from turning off then it is an overheating problem
Mar 22, 2008 | Samsung HCN4226W 42" Rear Projection...
HCN4226W problem
Voltage regulation problem...accordianman
Feb 15, 2008 | Samsung HCN4226W 42" Rear Projection...
Screen is blank
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 08, 2007 | Samsung HCN4226W 42" Rear Projection...
My samsung model- HCN4226W T.V will not turn on
You should always have all expensive electronics on a surge protector. It sounds like for this set the power regulators blown out as I know this set very well and seen it a hundred times!! its a power regulator IC that cant handle a power surge at all. and if thats your only problem, it shouldnt cost more then 175.00 to 250.00 to repair. Now with a surge though there could be other problems as well but from what you stated Im guessing alls ok except what i stated. Now Please do not attempt to repair yoursels, as these sets have alot of Hi voltage inside them even when they are unplugged.. Good Luck
Jun 28, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
256 people viewed this question
Henry  Thomas
Henry Thomas
