Question about Kodak Digital Projector DP1100
Reset lamp timer and making the picture bigger.
I need a new lamp soon and i lost my manual, so how do i reset the timer?
also how do i get my picture bigger?
    President:
  • 788 Answers
Here is a link to your owners manual, and below is the reset procedure.
http://www.kodak.com/global/plugins/acrobat/en/service/digProj/dp900And1100/manual/referenceManual.pdf
To reset the lamp hour counter in the Status window, press
and hold the left mouse button, then press the menu button
(while still holding down the mouse button) for 5 seconds.
Verify that the counter was reset by pressing the menu button
and viewing the counter in the Status window.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 02, 2009
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
Can't reset lamp timer for new bulb
when you replace old lamp with new one the lamp timer not reset automatically the counter is a software data and you reset manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
RESET +LEFT ARROW KEY+ RIGHT ARROW KEY+ENTER (as show in picture)
Feb 10, 2011 | Sony VPL-ES2 Multimedia Projector
Tv image will not show , it turns off it says ... something about the lamp inside the tvneed to be replaced?
The lamp timer on your unit has reached the max hours. it needs to be reset. There should be a reset feature in the menu. You should replace the lamp. It will brighten up your picture too. It must be done soon as once the timer reaches a limit your unit will not turn on at all. Check your manual for proper lamp type and replacement proceedure.
Feb 27, 2010 | Panasonic Televison & Video
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
My samsung tv was making a loud wining noise then a pop.
you need to replace the lamp and if you have , you now need to reset the lamp use timer, so that it can start the new timer on the new lamp.
Jul 05, 2009 | Samsung HL-67A510 67" DLP HDTV
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Reset lamp clock
you need to reset lamp timer this is to tell set it now has new lamp i have the information at my shop as soon as i can , I will up date this with how to reset timer.
Dec 29, 2007 | Zenith D52WLCD 52" Rear Projection...
Kodak Digital Projector DP1100 Logo
251 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
