Question about Nokia N70 Cellular Phone
Issue with display
Sometime the screen would show black and white verticals line on the screen and i was not using the phone.I have already formatted the phone however it happened after that as well.The issue seem to be a intermittent issue.After this happens i would have to restart the phone by taking out the battery.Also if could get some intruction to open the tear down the phone so that i could clean it of the dust which is coming on the screen. Thank you i too have an issue with the display screen.. its blank white............. not able to use it at all... pls help..
  • 421 Answers
Sir please upgrade your phone for solving your problem
Posted on Jun 02, 2009
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
White screen
just format your format your phone using twister/ tornado or jaf box because the software of your phone was corrapted
Jun 02, 2008 | Nokia 7610
Display screen turn half black
hi there
you need to replace the screen because that means that you liquid matrix display ( LCD ) is already busted.
hope this helps.
Jan 29, 2008 | Cell Phones
Issue with display
This is hardware problem. You can't solve it yourself. You must go to noikia service center
Dec 24, 2007 | Nokia N70 Cellular Phone
Display Issue
format once before that u back up the phone memory in memory card ... And to format switch off the phone and again switch on the phone simultaneously pressing the dial key ,* and 3 ... u'l get a black screen called formatting ...
Dec 03, 2007 | Nokia 7610
Nokia 7610i shows white screen
just re format your fon for highest version
Aug 22, 2007 | Nokia 7610 Handheld
Nokia N70 Cellular Phone Logo
161 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
