Question about Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range
Kenmore Gas range control panel error code ''8''
I have a Kenmore gas range that has an error code number ''8'' on the control panel display. Burners work but the Oven and broiler are not functional. I am guessing I have a bad control panel, what do you think? If ypou suspect a faulty CP, how difficult is it to replace and what is replacement CP cost? Thank you in advance for your assistance, Victor
  • 15,935 Answers
It appears your clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
I have a kenmore portable ac 12000 btu model number on the side says 35132 i have a serail 351321102073 i have a e3 code displayed what does that mean?
The E3 F1 error code indicates a Fuel Type Failure. The control board on the Kenmore ranges and ovens that use this error code can detect whether the control board programming is set for electric (E) or gas (9). The troubleshooting for this failure is to unplug the range or shut off the breaker to completely kill power for 30 seconds. After powering the unit back up, hold the CANCEL and START/ENTER keys for 5 seconds. You should see "E" for electric or "9" for gas. If you have an gas range and the "E" is showing for electric, then the electronic oven control board will likely need to be replaced. The opposite is true if you have a gas range or oven.
Jun 13, 2017 | Kenmore Heating & Cooling
1. Sears Kenmore Gas Range 2. Model No: 362.75481890 The oven will not ignite. The igniter-oven burner will glow but the gas will never start to flow. This has gradually occurred and has now come to...
Hello Everett,
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when set to bake ignitor by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than that replace bake ignitor. If you dont have amp meter take my word for it since in my 30 years appliance repair career i have when the ignitor comes on, that it's weak, to be the problem 100% of the time
Jul 31, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Error on display F1 & E1 Stove will not start
HI. This is a safety flip flop error code, caused by damaged circuitry within the electronic control board. This will require you to have the control replaced asap. This will correct the issue.
Part number (for white control) #3196971
Part Number (for black control) #3196970
Oct 19, 2009 | Ovens
Oven not working
Your electronic control panel must be replaced.
Feb 27, 2009 | Kenmore 73422 / 73424 / 73429 Gas Kitchen...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range Logo
178 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
