Question about Vacuums
Wiring diagram Need wiring diagram for the motor wiring.
  • 43 Answers
HI, tell me is this you want,,
Posted on Oct 24, 2007
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
I need a good wiring diagram for my Oreck xl vac
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Need a wiring diargam to look at
You won't find a diagram.
You will have series of yellow and white and sometimes gray wires on the outside of the motor housing and often a letter code etched on the housing , indicating the original wiring from years ago, red, blue, yellow, however the newer wiring eliminated those colors.
These wires are almost fool proof as they will align with the longest wire at the furthest point,a center one piggy backed , etc however before starting please post back to advise if you have removed the rewind and or motor and if so, did you disturb the motor wiring inside the motor shroud.
Please post the original problem you opened the vac for as well and I will try to walk you through this
Nov 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Here are the 4 different wiring for new Oreck motors.
Apr 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
backwards wiring. The motor will still run but the lights keep going out right?
Oct 23, 2007 | Oreck XL Ultra Bagged Upright Vacuum
Electrolux 2100 canister vacuum
Open the door to remove the bag. Pull the side bumpers forward when the door is open. The profile of the edge of the top and the bottom of the vacum body is a "L" shape. The cross section of the bumper is a "I" and that holds the body together. Carefully lift up the top just a little to free the plastic end cap that conceals the cord spool. There are two plastic pins on the top and bottom that hold this piece on and they frequently get broken. (If that happens repair shops drill and hole and insert a screw.)
There is a plastic protector plate that lifts up on either end and then is slid about 1/8th inch clockwise and then up.
Copy the wiring pattern on the four male connectors on the motor and the wire spool.
Post your wiring diagram and it will solve a lot of people's problem trying to reassemble this machine's -- including mine.
Oct 07, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
687 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
