Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
PLEASE DO NOT TRY TO FIX THE PROBLEM YOURSELF. You should hire an authorized service company to evaluate and fix the fryer.
Cecilware had a well known problem with their thermopile F178A. There was a recall on it last year. There are a few that are still in the field. It's possible your fryer might have one installed in it.
Their website doesn't have the manual posted. You will need to call them. 800-695-4500
Good luck
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane. ****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
To convert these to LP you must downsize the burner orifices and the pilot orifice. Also you must change the regulator on the gas valve to LP. Easy job.
Replacing the tank isn't cost effective. I am the only one I know that repairs fryer tanks. Most cannot be repaired(welded) successfully. If you got 8 years out of it..that's not bad. Time for a new one.
Goto 3wire.com.Search the site with the s/n.To do the conversion you need to change the pilot,burner orfices,gas valve and pressure regulator depending on the model but usually their all the same.Any questions let me know.
on that cecilware fryer there is a regulator to the right of the pilot light unsrew the aluminum cap and take off cap then you will see a white plastic screw turn that screw clockwise until it stops this will give the fryer more gas this could be your problem the regulator is silver and inline with the gas pipe comming from the back
Hi, The gas jet is too large and the gas valve needs adapted for lp gas. Lp gas has more pressure so the jets are smaller. Any appliance parts store should have the kit needed to adapt the gas valve along with the jet. The valve pressure will also need to be adjusted using a cheap water column gage also available at the appliance parts store. Check with them on what the pressure needs to be in your area. If the regulator is part of the lp it should be set right. If it is part of the fryer, set up for natural gas, and there is no lp regulator, it will need to be adjusted and or replaced with an lp regulator. Gas companies are usually very helpful with such things because they are concerned about gas safety. Good luck.
