Question about Lands Phones
Phone won't ring with incoming calls
My phone won't ring with incoming calls and the answering machine won't pick up ,but I can call out. I have a recent problem with my landline telephone: the phone doesn't ring, but callers report hearing the ring tone indicating the call is connected. However, I can still call out. The problem occurred with a cordless Uniden phone with answering machine, but to test that the problem wasn't the phone, I switched it out with an old-style push-button phone that doesn't require power from a wall outlet, without success. I also changed out the cord connecting to the phone base to the old-school phone and new cordless, without success. At each change, calls would not ring through, but I could call out. One additional strangeness. If I call in via my cell phone, and wait for the tone indicating the home phone is ringing, then answer the home phone, the call connects!!!
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
Move the phone to a different outlet and see if that solves your problem.
Posted on May 01, 2011
5 Suggested Answers
  • 14 Answers
SOURCE: Uniden Cordless Telephone with Dual Handsets and Caller ID DXI-55
check if you have a manual. from there search up in the manual caller id settings. you have turned off the caller id option.
Posted on Nov 15, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
have the same problem with a Panasonic KX-TG9344T phone bought from USA used in india. is it a local generated problem?
Posted on Jun 28, 2008
rylee_smith
  • 8619 Answers
SOURCE: UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 16, 2009
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Fax is not coming through.
Jul 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
I recently got this old "Panasonic Easa Phone KX-T2835" from a thrift store and my phone only rings twice before my answering machine picks up. How can I make my phone wait till 4 or 5 rings before it...
Have you tried erasing all the (incoming) messages on the machine? Does that let it ring the full 4-ring-cycle before it picks up?
It's been years since I owned one of these, but there should be a switch (on the side of the unit?) for a feature called "toll saver" If you find this, switch it off.
The idea was from the days of payphones -- if the machine had no messages, it would ring 4 times before it picks up. If there were messages, it would pick up after one ring (or sometimes two)
If you were out on the town and wanted to check your messages, you'd put your dime in a payphone and call home. If it rang three times, you can hang up the payphone and get your dime back, knowing there's no message to check.
Jun 14, 2010 | Panasonic Lands Phones
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
Nov 02, 2009 | Lands Phones
Can't get incoming calls on either handset
Thanks, but the batteries would cost me a lot so I might as well just get new phones....
Jan 11, 2009 | Vtech T2435 Dual Handset Cordless Phone
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Fax and phone ringing together on constant
The fax machine has a setting for the number of rings before it picks up. It's different for each model but you should find it in the manual, no problem.
Jun 13, 2007 | Samsung SF-350 Plain Paper Inkjet Fax
Lands Phones Logo
10,096 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
