Question about HP PAVILION A6230N DESKTOP PC
My HP cpu has problems starting up
I have to remove my printers from cpu to get it starter into windows. when windows opens everything seems fine. whats the problem?
  • 741 Answers
Your power supply may not be able to push enough power to use the printer..sometimes HP will put the minimum power supply wattage to save money..open the case and look at the power supply and let me know what the wattage is.it will be on a lable on the top of the power supply.should be at least a minimum of 400 watts.
Posted on Jun 02, 2009
What is hpdevmgmt(2)
It's your HP printer background software. If you change the services to manual from automatic they won't start until you need then. Control Panel\Administrative Tools\Services. Don't change anything except hp services. If you don't have an HP printer anymore uninstall everything to it.
Jan 12, 2015 | Dell Inspiron Computers & Internet
HP Officejet 5610 All-In-One
The drivers and software is available on the hp website, just a moment.
Jun 26, 2008 | HP Officejet 5610 All-In-One InkJet...
My hp compaq start misbehaving this morning when i boot up the system, it works fine. immediately i try playing around with windows or opening any high resolution programme, the CPU seems to behave like a...
Try downloading the latest video driver. it could just be a faulty driver file. Make sure the heatsink is clamped to the CPU correctly. this is much more important than having thermal paste on it. If someone has removed the heatsink, they may not have replaced it correctly
Sep 18, 2013 | HP Computers & Internet
HP PSC 1210 PRINTER switches off when print command is given. Scanner and copier works fine. unintalled and reintalled several time .problem persists
Shukla,
It seems that the printer drivers are corrupted while the copier and scanner drivers are fine. Disconnect the device from the computer, uninstall the device from Control Panel->Add Remove Programs and reboot.
Once rebooted, reinstall the device drivers from the CD that came with the device. Connect the device and allow Windows to autodetect it and load its drivers. Windows will tell you in the right bottom of the screen "The new hardware is installed and is ready for use".
Start printing.
Feb 10, 2011 | HP PSC 1210 All-In-One InkJet Printer
I have an HP LaserJet 3015. I got a new computer
- uninstall everything again
- browse your disc
- open "Setup" folder
- copy "Scrubber.exe" and "scrubber.ini" to your desktop
- run "Scrubber.exe"
- restart PC
- reinstall software
- enjoy
- p.s. this will not work under windows 7
Jul 02, 2010 | HP LaserJet 3015 All-In-One Printer
I Have hp officejet Pro L7590 and Hp 5610 alin one
if the windows was reinstalled.. you should also reinstall the driver for your printer.
Jul 04, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP photosmart C7180 all in one not printing properly.
As explained by you it seems to be an issue with the printer drivers.you can follow the following steps .
steps ...
1. Open a Command Prompt window
key the commands
net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 .
delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves.
4 Start > run > type > regedit .
Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
There might be two entries names Version-2 and Version-3 under drivers: click the plus sign against them and remove everything under them.
4. In the run (Start Search for Vista) type : c:/windows/system32/spool/printers: delete any files there.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
2. net start spooler
Then follow these >>>>
> browse the disc n go to folder util > ccc > there you wud find some uninstall files > run uninstall _L1.bat.
make sure the printer should be unplugged while you perform the steps .
> then insert the disc and click on add a device .
follow the instructions and connect the us cable when prompted .
Hope this helps .
Take care
May 19, 2008 | HP Photosmart C7180 All-In-One InkJet...
Found New Hardware error message
that can come from having two of them on the printer profile..open that to check if the computer is looking for two printers.
Mar 10, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PAVILION A6230N DESKTOP PC Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
