Did you wire them in circuit? (hot lead to positive on 1st batt, which jumps to the neg on 2nd batt, and neg lead going to neg post on 1st batt, then to positive on 2nd batt) That would be for a 24v system, for a 36v you would continue to the opposite posts again.
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a...
(More)
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
One of the front power jacks will not work. The motor side works great. The orthe side the gear on...
(More)
One of the front power jacks will not work. The motor side works great. The orthe side the gear on the shaft from the motor turns and it also turns the gear that raises and lowers the jack but the jack does not move. Are thys a pin that has been sheared and can it be fixed?
