Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer frosts up and stops cooling after approximately 2 weeks
Fridge starts warming up...ice forms on the rear panel of the freezer....I removed the panel and the coils are iced over... this is a weekly problem S# GZ251775 M# TFX20JRBK WW
    Problem Solver:
  • 16 Answers
Either low in freon or defrost timer stuck or unit needs cleaning, remove front louver panel on bottom (either 2 screws or snap fit) look for timer then use small straight screwdriver to turn slowly till clicks then wait to see if working properly, if not could be problem. if you see a lot of dust bunnies while doing then clean with vacuum and do same to back area also
Posted on Jun 02, 2009
Additionally, your defrost heater may need replacing.
Posted on Jun 04, 2009
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
Freezer blowing air but getting warmer and stopped making ice. Fridg also seems to be warming up. no unusual noise.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. But if the freezer also gets warmer it can be failure of the auto defrost making the vents choked. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Sep 20, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
I have an LG ref with Model GR-T382SV. The refrigirator does not get cold but the freezer is fine. What could possibly the problem.
Hello there,
If a section of your refrigerator is not getting cold, either the fridge or freezer compartment. It means there is a problem somewhere in the unit of the refrigerator that needs to be checked.
There are some parts to quickly check on the refrigerator to be able to see where the fault is from. Once checked you will be able to tell what the cause is and how to solve the problem.
Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils (under the unit) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost thermostat, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
If you have frost build up, it simply is caused by one or more of these factors either faulty defrost thermostat, defrost heater or defrost timer. Have them tested and replaced once the faulty component is detected.
All the best
Elect_Comp
Sep 19, 2011 | Refrigerators
Top freezer working fine. borrrtom fridge not cooling
Top of Form
Sep 05, 2011 | Samsung Refrigerators
My LG Refrigarator with a top freezer and water dispenser is frosting on the freezer and the refrigerator is warm
Top of Form
Aug 12, 2011 | LG Refrigerators
KENMORE REFRIGATOR FREEZER THE FREEZER WORKS FINE THE REFRIGATOR IS WARM
Jul 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
We have a Frigidaire FRS202RG side by side fridge/freezer that is about 9 years old. In the last 3 months, it has begun frosting up in the bottom of the freezer with ice forming over the vents at the back....
Sounds like the fan behind the rear freezer panel has stopped working,therefore no air flow over evaporator coils causing ice built up and no cooling on refrigerator side. easy fix
Nov 30, 2010 | Frigidaire FRS26ZSG
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
382 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
