Question about Acer Aspire 5100 Notebook
I can't boot my computer
It won't let me boot my computer and when i do the "restore failed - reason 0xa000000e" box pops up
Try safe mode tap F8 on start up and click ener by using the up and down arrows and click safe mode by hitting enter
Posted on Jun 02, 2009
I cannot restore to the original setting error oxf0000005. I lost the cd
Try the Ultimate Boot CD (UBCD).
See a pretty nice description here:
http://www.barrywheeler.ca/acer-aspire-restore-failed-reason-0xa000000e/
Aug 09, 2011 | Acer Aspire 5102WLMi Notebook
I would like to factory restore but I have no disks. My start menu won't work & sometimes I have to manually launch the internet by going into task manager. The problems are just one to many...
if your running xp home or pro sp2 or sp3 i can help from hopefuly
the first thing we need to do is to boot the system fresh in safe mode
heres how to do that,
1).push power button at first screen with big hp on it push f8
now for reference f2,is for cmos, and f12 is for boot preference
after you push f8 diag screen willcome up using the up and down arrows scrool up to safe mode then hit enter (return)
a pop up windows will ask if you want to run in safe mode click yes
after the system has booted (push the start button and the push run)
in the field type msconfig .... this will bring uo your configuration utility,,
theres a couple of things we need to do here first click on the startup tab
you see all those boxes with check marks uncheck all except the ones that have hp in them.now push apply,DONT PUSH CLOSE THOUGH,instead open the general tab at the top of the configuration utility, and now you can push the system restore button \ answer yes you want to restore your system to an earlier time\ itll bring up some calenders for you to choose a date\choose a date when you know the computer was running well have a great day
also form the task manager you can type msconfig and bring up the utility
if all else fails email me at makintyme@hotmail.com and ill send the disks
Jul 10, 2011 | HP Pavilion a1230n (EG134AA) PC Desktop
Asks me to When I run my recovery disk that Acer sent me this is what occurs, System disk runs and loads fine I F12 as instructed by Acer and then wait Asks what language I want instruction in I choose...
Either you DVD is corrupt, OR the DVD reader is not working correctly. It seems the reason the restore failed, is that it "Thinks" the Hard Drive is corrupt, too corrupt to replace the OS on...
The only thing to try now, is to get a Windows install DVD, put DVD in drive and boot from the DVD, then try to install with that, when you get to installing and it asks if you want to Format, do so, format Full NTFS. Then try to proceed to installing. If this too fails then you will need to replace your hard Drive, quite a simple matter.
Mar 06, 2010 | Microsoft Windows Vista Home Premium with...
I'm trying to wipe my hard drive with Fedora 12 and three partitions. I have 1 system disc and 3 recovery discs from Acer. After installing files from the system disc, I replaced it in the DVD drive with...
Jeff what you have to do is this dont disturb yourself just go straight off the system then later on it and press your key F11 down at a time simultaneously then it will bring the system recovering factory settings for you and follow the instructions then you are through is just that all you have on the system will be gone but you will have your system back alive the way it was manufacture to work BYE THANKS
Feb 20, 2010 | Acer Aspire 5520-5908 Notebook
Acer aspire 5720z restore failed 0xa000000e''
reinstall OS as your system has virus and it has corrupted the system files
Oct 12, 2009 | Computers & Internet
Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Aug 07, 2009 | Dell Computers & Internet
Restore failed - reason 0xa000000e
Did you install a new hard drive in the Acer? They have had problems when trying to restore windows onto a new drive or trying to use system restore on the existing drive. The same error message comes up.
It seems that when the pqservice partition is not on the drive, the recovery DVD won't work if the drive contains any partition (Restore Failed - reason 0xa000000e) is all you will see.
However, try deleting everything on the drive (leaving only unpartitioned space) before putting in the recovery DVD. The eRecovery tool first says that it is repartitioning the drive and then starts the install successfully.
I hope this helps.
Jun 02, 2009 | Acer Aspire 5100 Notebook
Restore failed reason 0xa000000c.
this error is referring to a bad MBR (Master Boot Record)
which basically means that you will need to take steps to either recovery the master boot record or restore your computer using the the recovery disk.
Apparently acer has a partition specifically for recovery.
did you repartition your hard drive?
Try Booting and pressing ALT F10 and that may take you to a recovery console.
May 24, 2009 | Acer Computers & Internet
Acer 5520 restore failed 0xa000000e
I got it to work by deleting all the partitions on my drive (I first loaded xp, loaded system commander 9, and used that to delete all the partitions.)
Then while booting from the recovery cd, holding down alt-f10, the recovery dialog said it was partitioning the drive. (I didn't see this before, even if I partitioned the drive like it came from the factory.)
Then the rest of the recovery worked.
Feb 11, 2009 | Acer Aspire 5520-5908 Notebook
.After instaling (sys inf) my iphone shows only appel icon .
use itunes applications tab for your iphone to remove (by clearing check box) the sys.inf (if it is an application) you of course have to have your iphone connected to your computer to do this.. click apply and the phone shoould sync with itunes and remove the application that (may) be the reason your iphone won't boot... If this fails try a restore of your ipone using the button in the summary screen for your phone in itunes
Aug 07, 2008 | Apple iPhone Smartphone
Acer Aspire 5100 Notebook Logo
264 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
