Question about Dryers
Have a problem reassembling the drive belt and pulley on Simpson Model 39P452 Maxidry 425 dryer. Can't work out where the spring is atttached and which way around the pulley goes. Can you shine some light and forward simple instructions. Don't want to waste valueable money on a tradesmans visit. Cheers heaps
  • 483 Answers
We take out your lint filter, you will notice 2 screws, unscrew them, pop the top up using a putty knife or flat screw driver, you have clips on the left side and right side.
My 2 cents
Thanks
Fame !
Posted on Jun 02, 2009
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
How to wire Simpson 1200S dryer motor
Check with Simpson directly to obtain the diagram.
Jun 10, 2014 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Hi i need to fix the belt that rotates the dryer
MOST SERVICE COMPANIES WILL HAVE A BELT, OR RING SIMPSON ON 131350
BEFORE YOU FIT THE BELT MAKE SURE THE CENTRE PULLY IT GOES ON SPINS FREELY- IF ITS TIGHT IT WILL RUIN THE NEW BELT.
Jul 06, 2009 | Dryers
Replacing the belt on a simpson 362 maxidry
Check out applianceaid.com good easy site to follow
Apr 19, 2009 | Electrolux Dryers
The belt of DRYER broken (simpson maxidry 10s) . I want to find the belt. thanks
do a google search for your model number of dryer and put the word "parts" after it, there is a lot of sites that sell parts at good prices
Oct 28, 2008 | Dryers
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
